Where can I get 4.11 gears for 10 bolt?
Old Jan 22, 2005 | 09:39 PM
Kreinmc's Avatar
I am putting 4.10s/4.11s in my car and I have heard that 4.11's are stronger because of the difference in the number of teeth. Are there really 4.11's made for a 10 bolt? If so where can I get em?
Old Jan 22, 2005 | 10:14 PM
rskrause's Avatar
Moderator
Re: Where can I get 4.11 gears for 10 bolt?
I don't think there is a 4.11 for the 7.5" 10-bolt.
Rich
Old Jan 22, 2005 | 10:23 PM
LT1Squirrel's Avatar
Rich
werd
Old Jan 22, 2005 | 10:25 PM
med_reject's Avatar
slp sells gearsets, but i dont know if htey fit in the stock rear ends. www.slponline.com
Old Jan 22, 2005 | 10:30 PM
Kreinmc's Avatar
http://web.camaross.com/forums/showt...ght=4.11+teeth
These links lead me to believe that it is possible to get a 4.11 for a 10 bolt. I will contact motive on monday and see what they can do.
FryedClutch's Avatar
i actually think summit racing might sell them
Old Jan 22, 2005 | 11:01 PM
93LT1355's Avatar
I've checked SLP and they only make 4.10 for the 7.5 rear end.
Old Jan 22, 2005 | 11:22 PM
unvc92camarors's Avatar
motive makes them
9 ring 41 pinion or whatever
a couple of people on here have them, just search for them
Old Jan 22, 2005 | 11:27 PM
93LT1355's Avatar
Does Motive make a good gear set? I'm in the market for 4.11's or 4.10's
Old Jan 23, 2005 | 12:41 AM
cmking26's Avatar
Ive got a set of GM 4.11's. Haven't installed them yet but I hope they fit. I think they will.
Old Jan 23, 2005 | 12:52 AM
Spinner's Avatar
Rich
GM motive gears are 4.11s even though they're listed as 4.10s, I have a set in my car, they are
37 tooth ring
9 tooth pinion
= 4.11
Old Jan 23, 2005 | 01:11 AM
Brent94Z's Avatar
Super Moderator
37 tooth ring
9 tooth pinion
= 4.11
Same here. I destroyed my 4.10s and didn't want to go through a big setup routine so ordered Motive 4.10s again. They came in and were completely different... actually stamped as 4.10s but were really 4.11s. I posted this before in another thread...
FWIW, when I broke my GM Motive 4.10 gears, I ordered another set of the same gears. When they came in, they were very different (like you said, different number of teeth) and while they were stamped 4.10 right in the steel, they were actually 4.11s
Old Jan 23, 2005 | 08:57 AM
37 tooth ring
9 tooth pinion
= 4.11
ahhh, that was the right calculation 9/37
disregard my 9/41 comment everybody, it was late last night
Old Jan 23, 2005 | 09:13 PM
Capn Pete's Avatar
Uh huh.
To set the record straight:
41 / 10 = 4.10
37 / 9 = 4.11
So it's MOTIVE that makes 4.11's for the stock 10-bolt, eh? I've always heard they're out there, but never knew WHO built them.
Old Jan 24, 2005 | 03:39 PM
Kreinmc's Avatar
So if I call up thunderracing and order motive 4.10's I will get a 37 and 9 gear? I called motive gear themselves and they said they have a regular 4.10 and a performance line gearset. The guy did not know the exact number of teeth on the performance line gear.
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ddr698
Jan 9, 2015 10:05 AM
Perry93TransAm
Aug 20, 2002 11:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
