Power Problem Is Back!!
Old Jan 12, 2005 | 11:33 AM
camarobiatch
Guest
Posts: n/a
OK my problem has reaccured. It seems that when I let off the gas and the RPM's are going down the lights dim and the battery needle fluctuates from normal to low to normal. It happens even at an idle while revving the gas a bit. I have a 2002 3800 v6 camaro with 20,900 on it. I've already had the alternator changed ( under warrenty) and am hoping it is just a loose ground or a short somewhere. Anyone else have this problem? I'm taking back to dealer and was wondering if they put it on the computer if they will be able to find a short or loose ground..thanks
Old Jan 12, 2005 | 01:30 PM
Teufel Hunden's Avatar
Re: Power Problem Is Back!!
Yeah, it sounds to me like just a wiring problem. There's a small chance that new alternator was defective out of the box.. i've seen that happen more than once. So you might want to get that retested anyway, and then the hunt wor wiring problems can begin.
Old Jan 12, 2005 | 11:38 PM
atl2001's Avatar
From: carbondale IL \ Alton IL (outside St Louie MO)
first random thought: never hope its a short or a loose ground... looking for a loose ground or tracking a short sucks ***
second random thought: look at your belt, check to see if it looks worn, its possible that the tensioner pulley isnt working and the belt isnt turning properly all the time and the alt isnt spinning fast enough to provide enough juice
third random thought: the second random thought isnt all that likely, but ive heard of it happening before
Old Jan 13, 2005 | 01:35 PM
camarobiatch
Guest
Posts: n/a
I also had a new belt put on when they replaced the alt the first time. I guess I'll know soon enough ...taking the car back to the dealer Monday..As for looking for a loose ground or short, some of my mechanically inclined friends already offered to help me look on a Sunday afternoon!! suckers !!!!!
Old Jan 22, 2005 | 05:49 PM
Antz97ZNJ's Avatar
think the power problem is the 3800, lol j/k kinda...if you only bought the car a mth ago...Id bring it right back to where you bought it...let them worry about it
Old Jan 24, 2005 | 01:54 PM
camarobiatch
Guest
Posts: n/a
Problem is fixed sailing smoothly
jane
Old Jan 24, 2005 | 09:32 PM
Javelin3o4's Avatar
what was the problem?
Old Jan 26, 2005 | 01:34 PM
camarobiatch
Guest
Posts: n/a
the problem was a defective alt out of box ..just my luck
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Alucard
Jul 29, 2002 10:30 PM
