26 vs 28 spline
Old Jan 9, 2005 | 10:09 PM
Kwiksilverz28's Avatar
26 vs 28 spline
I am rebuilding a rear for my GTA, and the one I bought has 26 spline axles. I think Moser sells new 28 spline axles. I have not bought the rest of the internals, so is the $235 going to make that much of a difference, or should I put that money into the bank for the future 12 bolt if I ever toast this?
Old Jan 9, 2005 | 10:17 PM
mrr23's Avatar
Re: 26 vs 28 spline
mike, don't worry about it. you aren't putting out that much power to twist the axles, yet.
Old Jan 9, 2005 | 10:31 PM
Re: 26 vs 28 spline
That is my thought, but say N2O or forced induction......is it really going to make that much of a difference?
I knew you would know. I need to just call you first!
Old Jan 9, 2005 | 10:34 PM
mrr23's Avatar
Re: 26 vs 28 spline
i can't say at what level a 26 spline will break over a 28 spline. but everyone talks about how weak a 7 5/8 10 bolt is anyway. one day i'll break one. two cars running 11s on the bottle you know.
Old Jan 9, 2005 | 10:38 PM
Re: 26 vs 28 spline
Good point. Time to order parts.
Thanks!
Old Jan 10, 2005 | 11:34 AM
bubba353z's Avatar
Re: 26 vs 28 spline
How far are you planning to go, with this rebuild? If you are contemplating a spline count change, then you're obviously planning for a new differential. Add new gears, seals, and bearings - and you'll be close to $1,000 in parts. Add an aluminum cover - another $150. Any labor will take you even higher (if you can't do it yourself) - see where I'm going.
I'm in the rebuild vs. buy stage, right now. I figure I'll have $1500 - $1700 in redoing my 10 bolt right (I'd have to pay someone to build it). For another $1,000 I can have a Strange / Moser. I currently don't have the power to bend a 28 spline axle - but I might be able to blow up a 10 bolt, under the right (wrong) circumstances.
Old Jan 10, 2005 | 02:44 PM
87DJP2001's Avatar
Re: 26 vs 28 spline
The main difference between the 26 & 28 spline Axle shafts is the 28 splines make for a tighter fit with mating parts with no backlash. They are not stronger material wise per se then the 26 spline shafts.
Old Jan 10, 2005 | 07:03 PM
Re: 26 vs 28 spline
http://cgi.ebay.com/ebaymotors/ws/eB...category=33731
$330
$160 plus 70 for rebuild kit
?$150 for install
$710 total. Another $100 give or take for aluminum cover. Not even close to $1500. If it were $1500, I would get a 12 bolt. If you look at those ebay deals, the diff is new. I will watch for a take off or low mileage used.... My goal is $600 total.
$2100 for a moser, plus brakes.
Old Jan 10, 2005 | 07:16 PM
87DJP2001's Avatar
Re: 26 vs 28 spline
$330
?$150 for install
The two items you linked are not compatible.
Old Jan 10, 2005 | 08:21 PM
Re: 26 vs 28 spline
Nice. Oops. Good thing I haven't ordered anything.
But, these are a good comparison for pricing. I just need to be careful ordering.
This was supposedly a 28 spline rear out of a 89, but I pulled an axle just to make sure. Glad I did!
Thanks for the input everybody! Good ideas start somewhere!
Old Jan 11, 2005 | 11:36 AM
bubba353z's Avatar
Re: 26 vs 28 spline
I think you are looking at the "HP" unit, on E-bay. I've been looking at the "pro" version and the Eaton - they are both about $500 @ Jeg's. (I figure since I'm in there, might as well look at using the premium stuff.)
I figured about $300 for axles, $200 for gears (in big round numbers). Add in a full bearing and seal kit and labor to put it all together, and I'm in the neighborhood of $1,500 (once again, big round numbers).
I'm sure I can knock a few bucks off by using e-bay, and getting some free labor. I may well go the same route as you are. I just don't know what my ultimate HP goal is yet, to make the final decision.
Good luck, whichever way you decide to go.
RUENUF
Mar 13, 2016 03:37 PM
karpetcm
Aug 14, 2015 03:02 PM
realistyc
Jul 28, 2015 07:32 PM
9t4lt4z28
Jun 21, 2015 08:18 PM
importkiller94
Jan 17, 2015 09:03 PM
