94 z with LS1
Old Jan 4, 2005 | 10:15 PM
94 BIGRED's Avatar
94 z with LS1
i need help guys, I just purchased a 94 z-28 with a rebuilt LS1 and M-6. At fist the rpm tach was off and now does not move i don't now whats the prob. If any1 does can u please help. Also want to now if i can cut splice the wiring and put an abs connector from a LS1 rear end and a sensor on top of the rear instead of the axel like and LT1 if the ABS INOP light will turn off or do i need a whole new wiring harness for the tach and abs. oh air bag light is also o n what can i do 2 make it turn off other then scratching it out
Old Jan 5, 2005 | 08:13 PM
Kataklysm's Avatar
Re: 94 z with LS1
Check the wiring for the tach. Is it the tach on the dash or an aftermarket one? Fix the problems to get the warning lights off...
Old Jan 5, 2005 | 08:28 PM
AL SS590 M6's Avatar
Moderator
Re: 94 z with LS1
There isn't a LT1 or LS1 style ABS. You either have traction control 4 channel (a sensor at each rear wheel) or non-traction control 3 channel with one sensor at the top of the center section.
Old Jan 5, 2005 | 08:47 PM
94 BIGRED's Avatar
Re: 94 z with LS1
its the orgianl tach its about 1,000 rmp to low from engine rev
Old Jan 5, 2005 | 10:54 PM
Z95m6's Avatar
Re: 94 z with LS1
I believe you are in big trouble. I know you can't put a 98+LS1 gauge cluster in a a 97LT1 Camaro or firebird because they are wired diff. or set up diff. for the new motor. You might possibly be able to swap in a whole 98+ camaro dash, and it might remedy the problem but its only a guess.
Old Jan 6, 2005 | 12:08 AM
white/blackss's Avatar
Re: 94 z with LS1
you would have to wire the whole car with a 1998 or newer ls1 harness.
Old Jan 7, 2005 | 09:47 AM
Moderator
Re: 94 z with LS1
Or you could check Painless wiring solutions. They have many harnesses prebuilt to adapt newer engines into older cars. They might have one for this application. The harness would interface between the cars wiring and the engine computer so that no guages would have to be changed. Now the fuel system is another story but it still can't be all that bad. LS1 tank and lines from a salvage yard.
Old Jan 7, 2005 | 10:53 AM
CCCCCYA's Avatar
Re: 94 z with LS1
Or, if everything else is working correctly, then you could just forget the stock gauge and get a nice autometer and put in it. The stock gauge is notoriously innacurate.
How bout posting up some pics too. I'd be interested to see how the front of the motor was done if the front end of the car wasn't switched over to late model as well...
Dave C.
Old Jan 7, 2005 | 11:09 AM
teke184's Avatar
Re: 94 z with LS1
something is different with the coil-per-cylinder design of the LS1 which has a different tach signal than the LT1.
i know you have to run most shift lights in "4cylinder mode" for them to run properly on an LS1.
that's most likely your problem.
13qtr
Oct 28, 2016 08:11 PM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
1slow93z28
Sep 1, 2015 06:22 PM
