Speed reading
Old Dec 18, 2004 | 10:53 PM
orange57's Avatar
Speed reading
how does the speedometer in a 2000 camaro with the 3800 read the speed? is it measured off the transmission? is it a digital signal? does anyone know who makes an aftermarket speedo that would be compatible with a 00 camaro v6?
matt
Old Dec 19, 2004 | 09:15 AM
Re: Speed reading
The vehicle speed sensor (VSS) is located on the tailshaft of the tranny. It sends pulses to the PCM. The PCM processes the pulse rate, based on values programmed in the PCM for tire diameter and rear axle ratio, and sends a signal to the speedometer.
Dakota Digital makes an interface that will handle a wide range of signal/speedo interfaces.
http://www.dakotadigital.com/Detail....-5/product.htm
DirtyDaveW
Dec 1, 2016 05:37 PM
edman
Mar 13, 2015 09:39 PM
NewsBot
Jan 11, 2015 06:10 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
