reverse wheel hop????
Old Dec 5, 2004 | 05:42 PM
touch109's Avatar
MY 02 SS tires hop when im going in reverse. the car is all stock .. only does it in reverse and i took it to my dealer and they don;t know why and only said dont go to fast in reverse. But they did replace my power steering rack but now it makes a thump when i trun to the right.. dont know wut might be wrong with that...
Old Dec 5, 2004 | 10:19 PM
5.0THIS's Avatar
Re: reverse wheel hop????
GM didnt design the cars to be launched in reverse The dealer was right, dont blaze the tires in reverse
Old Dec 5, 2004 | 10:58 PM
trackbird's Avatar
The suspension is designed to slightly lift the chassis on the launch (based on the "instant center" of the suspension). In reverse, the suspension will lift the axle and basically do the opposite. Do not do burnouts in reverse in these cars. Wheel hop is bad and can/will break things.
Old Dec 6, 2004 | 01:00 AM
Teufel Hunden's Avatar
Why would you be doing burnouts in reverse? Don't you feel like an idiot? If i saw someone doing that, i'd point and laugh. Basically, the answer to your problem is stop driving like that.
Old Dec 6, 2004 | 03:37 PM
touch109's Avatar
I'm Not Trying To Do Burn Outs. But If I Push The Gas A Bit It Starts To Hop.
Old Dec 7, 2004 | 04:29 PM
ronin013's Avatar
someone told me you shouldnt do reverse burnouts because the angle of the teeth on the ring and pinion gears can't handle a lot of stress rotating the opposite direction (not that anything in that dinky 10-bolt can handle alot of stress regardless )
if your not accelerating hard and its happening you have a problem. I go fast in reverse (not mashing the gas fast) and have zero wheelhop. i drive better in reverse then a lot of people do going forward its fun to freak people out. maybe something in your suspension is binding your either giving it too much gas in reverse or its some problem i never heard of
Old Dec 7, 2004 | 06:19 PM
Sunsceamer's Avatar
Well mine hops in reverse with the spec 3 I had and got 5 times worse with the stage 5. I cant go slow enough to stop it. normal driving it just hopes bad out of the driveway.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Beave2780
Jul 7, 2015 06:36 AM
SAR2K
Sep 1, 2002 10:49 AM
wytblur
Aug 5, 2002 02:03 PM
