LT1 to LS1/LS6
Old Nov 25, 2004 | 06:19 PM
Z28WannaB's Avatar
Question LT1 to LS1/LS6
Is the LS6 just an LS1 with a factory cam and head package? Or is there actually a difference in the engine?
The reason I am asking is because this one character I know swapped an LS6 into his Lt1 95' camaro. I just wanted to prove that it was a stupid swap because an LT1 or LS1 could produce the same power if not more for less money. All the LS6s I saw for sale were extremely expensive, I think they have an exclusivity deal because they belong to the corvette.
Just wanna know what you guys think of such a swap.
- Z28WannaB
Old Nov 26, 2004 | 01:43 AM
MachoCamachoZ's Avatar
Re: LT1 to LS1/LS6
LS6 is a similar block but not exactly the same, the power differences come from the cam and heads though.
Old Nov 26, 2004 | 01:44 AM
Re: LT1 to LS1/LS6
this is why 01-02 ls1 trim camaro and firebirds have a slight chance of being ls6 BLOCK but still ls1 heads and cam.
Old Nov 26, 2004 | 11:52 PM
TonyJ's Avatar
Re: LT1 to LS1/LS6
http://www.corvetteactioncenter.com/...06/ls1ls6.html
This is for '01. In '02, the LS6 cam specs changed. That and better cats added ~20hp
Old Nov 28, 2004 | 04:34 PM
Antz97ZNJ's Avatar
Re: LT1 to LS1/LS6
He probably would have been able to get a 383 stroker and produce more power then the LS6 for cheaper...but if you can afford it hey...i wouldnt b!tch about having a LS6 in my LT1 body...to each is own
Old Nov 28, 2004 | 09:07 PM
BirchMan98z's Avatar
Re: LT1 to LS1/LS6
a factory LS6 costs no more than a factory LS1 (assuming each comes with all accessories, pcm, exhaust manifolds, coil packs, intake, etc.) They're both around $7000 ready to go. Probably cheaper to go the bore/stroke way.
Factory replacement engines are around $5000, but you'd need the intake, throttle body, coils, exhaust, pcm, belt system, and accessories.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
