Yet some more why do I have knock retard questions.
Old Oct 5, 2002 | 11:16 AM
LTOne4Fun's Avatar
Stock car with LT4 KM. Always see 10-12 degrees of retard at WOT
Runs pretty good thouh so Im kinda worried about making the retard go away Thinking either a) the car likes les timing or b) it will really run good if i can get the knock to go away.
Old Oct 5, 2002 | 09:52 PM
Dave 96TA's Avatar
Re: Yet some more why do I have knock retard questions.
or c) someone stole your LT1 and replaced it with an LS1 Whatever its doing, the dang thing runs like a beast. I'd make sure the sensor is functioning properly...picked one up at the dealer for $36 out the door...should find it cheaper @ rockauto.com.
Old Oct 5, 2002 | 11:51 PM
LTOne4Fun's Avatar
An autotap log file
http://www.tbns.net/grannysshifting/atap/granny.atl
http://www.tbns.net/grannysshifting/atap/granny.log
Old Oct 6, 2002 | 12:22 AM
Dave 96TA's Avatar
Sorry man, access denied?? You can email me the logs, address is listed.
Old Oct 6, 2002 | 05:16 PM
90 Z28SS's Avatar
I totally just gave up trying to figure out why my car pulls soo much timing at WOT . I zeroed out my Max retard table so it cant pull timing above 2500 rpms and now monitor Knock sensor activity solely thru knock counts . Even with all the timing my car pulled , the knock counts didnt go up at all thru the run . Given that , I'm pretty sure its all false knock .
If you have the ability to do this , absolutly verify your retard problem is from false knock readings and pay close attention to your knock counts
Old Oct 6, 2002 | 05:28 PM
95Blackhawk's Avatar
In addition to what Z28SS said try this: Put a tank of 101 or 104 (unleaded) in your car and check retard.
Since you are posting here, I assume you are able to program your car. So reduce the aggression of the retard. If you are concerned with predenotation, keep your max retard the same, but reduce how quickly it retards the timing. Try reducing it to .2 deg/millisecond or less instead of stock.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
asilomar244
Jul 12, 2015 05:53 AM
