Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Cam install questions...
Old Oct 4, 2004 | 07:31 PM
mavricki18's Avatar
Having some trouble finding my self "16 retractable pen magnets" to hold the lifters up. Any one know where to find some? Or better yet anyone have the JRP tool that i can rent for a doay or 2?
I have read over ls1howto.com cam swap site and it looks pretty detailed. just wondering if any one has any tips or troubles while doing a cam swap that i should be aware of before i start?
Thanks for all the help, Dane
Old Oct 4, 2004 | 07:52 PM
Dave89IROC's Avatar
Re: Cam install questions...
go to murray's or autozone for the magnets, 99 cents each usually
Old Oct 4, 2004 | 09:27 PM
Timberwolf's Avatar
wish I had known sooner. I had the magnets. I think the kids have broken a few of them by now though. I got em at AZ
Old Oct 4, 2004 | 10:31 PM
mavricki18's Avatar
99 cents not a bad deal
Timberwolf- when you did your springs what way did you find best to keep your valves from falling in the combustion chambers?
Thanks again, Dane
Old Oct 4, 2004 | 11:01 PM
Timberwolf's Avatar
I used "option 2" here:
http://www.ls1howto.com/index.php?ar...25c6f662664afe
I also used a "Larry" valve spring tool... worked like a charm.
Old Oct 5, 2004 | 09:25 AM
Rippers_Evil_Twin's Avatar
Is this a ls1?
I just rotated my cam 3 times pulled it out carefully had new cam ready to go and slipped it in carefully. never used a magnet. My understanding in the guide I had is that there is somthing like a static ring that holds things in place on the LS1.
When removing the springs and replaceing them I used a air compresser set to a really low pressure and attached with a special adapter in the spark plug hole that kept everything seated nicely
Old Oct 5, 2004 | 01:06 PM
Timberwolf's Avatar
yeah, the lifter cups will hold the lifters. BUT it's a friction fit. if something happens... doors gets opened or shut, wind blows just right, a buttefly sneezes.. (you get my point) a lifter could drop at any time and then you are into a MAJOR ordeal. I felt safer using the magnets for extra insurance.
Old Oct 5, 2004 | 01:10 PM
1BADAIR's Avatar
I tried the JPR tool but found out the hard way that I got one of the very first ones and it would not work in 2000+ cars so I had to pick up some magnets. For the springs a cut off a normal $15 dollar spring compressor like the one shown in the instructions on ls1howto
Old Oct 5, 2004 | 01:57 PM
Murdock's Avatar
FWIW, I used magnets on the lifters and compressed air to hold the valves up. One point to watch out for: I've heard of people who had the magnet head fall off, dropping the lifter and magnet into the motor. Check your magnets out first, give a tug on the end to make sure they are solid and that the telescoping parts aren't going to come loose.
Also, if you get hosed and can't find enough magnets, I'm at 12 and dequindre and still have a bunch of them in my toolbox.
Old Oct 5, 2004 | 05:16 PM
mavricki18's Avatar
Thanks for all the help guys ill let you know how the install gose.
Old Oct 5, 2004 | 08:28 PM
QUASAR BLU's Avatar
What cam/spring combo did you go with?
Goodluck on the install
Old Oct 5, 2004 | 09:22 PM
mavricki18's Avatar
John, I got a good deal on a used MTI C1 222/222 .558/.558 112LSA real streetable so i can still use the car for daily driving in the summer.
I dont have the springs and push rods yet but i might be gitting a good deal on them from some one I know. Comp cams Chromemoly pushrods and Comp Cams Conical valve Spring p/n- 26918.
chuyz28
Feb 19, 2015 12:50 AM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
