need advice on monitoring/tuning software
i am almost done with my 95 pontiac formula..did alot of modifications.. was wondering what software out there is the best for monitoring the car..ive seen a few free ones,im really dont know what to look for..any input into what you guys use..and like is appreciated
Steve
Steve
Re: need advice on monitoring/tuning software
Originally Posted by 92rslt1
look for lt1 edit or maybee tuner cat.
those are not monitoring sofware those are editing. the best sofware for monitoring is datamaster you can get it from ttpowersystems.com. you get 20 free trials runs then ista 100 buck and well worth it.
what mods did you do to your car? you may need some editing software.
1995 pontiac formula 355 ci lt1 6 speed 3.73 gears,custom ground cam per rskrause recommendations,ati p600b with 12lb pulley,3 core front mount intercooler,3 angle valve job on heads,comp cams 1.5 roller rockers,pushrods,springs,titanium retainers,eagle connecting rods,scat crank,52mm throttlebody,granatelli maf,engine oil cooler,random tech dual cat y pipe,arizona speed and marine 1 3/4 headers,flowmaster cat back, accel 44lb injectors,speedpro powerforged blower pistons(engine compression approx 9.2 to 1) ls1 driveshaft, alumnium flywheel,new clutch,msd 6al and power coil, i think thats everythin.. i prob left out somethin but..heh ..i got a tune from pcmforless..loaded that recently...the car..runs...but we are in process of just sorting out a few vacuum lines..and hopefully will spend a few weeks tweaking the car.. so .a good monitoring program and a good editing program would be nice... thanks for the help
Steve
Steve
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
