Wierd Sound! :(! Sounds bad
Old Sep 8, 2004 | 12:33 PM
Z28WannaB's Avatar
So I am driving, and I turn off the music let off the gas and hear a knocking sound coming from the rear left. It is in synch with the turning of the wheels. The faster you drive lets say you are going 70 it makes a thump-thump-thump-thump sound.
If you are driving 35 its thump-----thump-----thump-----thump.
Any ideas what it could be? And prices? It sounds bad thats for sure.
- Z28WannaB
Old Sep 10, 2004 | 05:08 PM
Z28WannaB's Avatar
Re: Wierd Sound! :(! Sounds bad
BUMP! I've still got problems, does anyone have the slightest idea or could refer me to someone who might know?
- Z28WannaB
Old Sep 14, 2004 | 10:18 AM
Z28WannaB's Avatar
Bump, is this not the right forum.
I can't figure it out, maybe it is a bearing in the back left wheel well?
- Z28WAnnaB
Old Sep 14, 2004 | 11:29 AM
n2ceptor's Avatar
Rock in tire tread????? Bearing???? Warped rim????? Warped brake rotor???? Tire rubbing ?????? Caliper loose???? Worn shock???? Swaybar link bushing loose/worn????
Remove tire and take a look....
Old Sep 14, 2004 | 03:24 PM
SloTexanTA's Avatar
Can you feel anything with the sound? If you feel anything, it opens up a lot of options. If not, it narrows it down quite a bit. Best bet is to get under it and look .
Tom
Old Sep 14, 2004 | 05:28 PM
KenP's Avatar
To help diagnose the rear end noise, put the rear end up on jack stands and turn the rear wheels by hand. Can you replicate the noise/sound you are hearing and pinpoint the location? There are many possibilities.
Kenny
Old Sep 20, 2004 | 12:29 PM
Z28WannaB's Avatar
Thanks Kenny, I wasn't really sure how to diagnose the problem. I looked around the wheel well and nothing looked out of place. Im going to try what you said and post the results.
- Z28WannaB
Kenny
Old Sep 20, 2004 | 12:32 PM
Z28WannaB's Avatar
Rock in tire tread????? No way
Bearing???? Possibly
Warped rim????? Nope
Warped brake rotor???? Brand New
Tire rubbing ?????? Nope
Caliper loose???? Nope
Worn shock???? - Possibly
Swaybar link bushing loose/worn???? Possibly
- Z28wannab
Old Sep 20, 2004 | 02:39 PM
n2ceptor's Avatar
- Z28wannab
If you can see fluid on the shock, then its worn... I have that problem right now....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Mar 19, 2015 12:20 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
ModdedNerd
Dec 18, 2014 10:52 PM
