My top does not close
Old Sep 2, 2004 | 09:32 PM
PewterSS-2001's Avatar
Question My top does not close
Has anyone with a convertible a good guess what is broke? My top does not close, It does not have enough power to push the top up from the fold down position.
Is there a way to check the fluid level in the system..?
Or is it the pump that is shot..?
Or does someone have a guess?
Old Sep 3, 2004 | 07:31 AM
TraceZ's Avatar
Re: My top does not close
Mine struggles too, but does work. I dont think it is the pump, because mine only has 50K on it and rarely gets used. I'm thinking maybe the top needs to be lubricated at the joints, but I'm not sure if that is a good idea because I dont want to stain the cloth with grease.
Old Sep 3, 2004 | 07:39 AM
ishz28's Avatar
In your trunk, drivers side under the flap is the pump. It takes hyd. oil and can be checked and filled up. There is a lever on top of the pump, turn it 90 degrees out and it disconnects the hyd. pump from the system. You can manually pull up and down your top, without damaging anything. Also, look at your torx bolts on the frame joints, see if they are not too tight. When I get a rattle in the top over bumps the torx's need tightening, when the top goes up real slow, I tightend them too tight. I think the torx is a size 25, I used a flat racheting tool to insert the torx into to get to them, especially to tighten the bumpers that rest over the window. Hope that helps.
Old Sep 8, 2004 | 11:12 PM
2cub49's Avatar
Try giving your pedal a little gas as you're lowering the top.
When I had my underdrive pulley I had to rev up the engine a bit to get the top to move faster and get past the first fold.
Just a thought.
Keenan
Jan 19, 2023 12:24 PM
Victor Lamb
Aug 26, 2017 02:52 PM
1970judge
Cars Wanted
May 23, 2015 11:39 PM
NewsBot
Feb 6, 2015 05:00 PM
