LS1 swap
LS6 intake swap?
Im putting a LS6 intake on my 98 Z28. Where can I get the parts to do what ever I need to. For the coolant lines? Or is there any other way around this?
Re: LS6 intake swap?
ls6 is a decent intake, but if I were you I would get the lsx intake. i have heard good things from that...just something to look into though. good luck!
Re: LS1 swap
Stick with the LS6 at your power level.. there are alot more mods that would make more power for much less money. There have also been several issues of difficulty with the LSX that you might not be prepared for. FWIW: The dealer sells the coolant lines. They aren't very expensive.
Good Luck,
Josh
Good Luck,
Josh
Re: LS1 swap
Good Luck,
Josh
Good Luck,
Josh
Re: LS1 swap
I bought the car wrecked. I fixed it. Ive put headers on it, ngks, lid, free mods and a 125 shot. Put my et streets and skinnies on it. It wet 7.6 at 93 mph in the 1/8 on a 1.8 60. The LS6 intake will work fine for what I want. Im planning a stall, gears, maybe a cam and some tuning. Heck I should be good in the 6s in the 1/8 then. And maybe stepping the nitrous to some 150 pills. Anyways Im going to get the newer modle coolant lines.
carguyshu
Jan 22, 2017 11:19 AM
