how much gas?
Old Aug 23, 2004 | 10:15 AM
josh_95z28's Avatar
how much gas?
i just got my camaro 2 days ago, and i was told that its empty when its at 1/4 a tank, so if its at 1/4 a tank how many gallons do i need to completely fill it up
Old Aug 23, 2004 | 10:24 AM
RE AND CHERYL's Avatar
Re: how much gas?
Did they mean the gauge is messed up, because below 1/4 tank on the gauge the needle falls like a rock. I get about 220 miles in town to a tank of gas, but I can go 100 miles befor the gauge falls to 3/4 tank. Talk about a messed up fuel gauge.
I believe it holds around 16 gallons, but when I run mine to the empty line it only takes 15 gallons.
Old Aug 23, 2004 | 10:51 AM
unvc92camarors's Avatar
Re: how much gas?
yea, it's about 16 gallons
i ran mine down to an 1/8 (on the highway in 6th gear just trying to save every ounce of gas) so it might've been getting close but i guess i got lucky to get to the gas station in time
Old Aug 23, 2004 | 10:53 AM
Re: how much gas?
Rated capacity is 15.5 gallons. If you fill it to the brim, you will get a little more in, but that's not necessarily a good idea, since it can put fuel into the charcoal EEC canister. From watching my gauge extensively, when the needle was exactly on the "1/2" mark, I had used 10 gallons, and had 5.5 gallons left. When the gauge was on the "1/4" mark there was less than 1.5 gallons left. Do NOT let it run out... it will likely damage the fuel pump.
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
