Another...Camshaft question
Old Aug 18, 2004 | 06:15 PM
CRZYPWR's Avatar
I just bought a camshaft for my car. Its a Lift: .595/.595 Dur@.050: 242/242 LSA: 112. My car is an auto. I have full bolt ons mods already,full exhts.full intake.(ported heads on the way) I was wondering if this is going to be pain in the *** to drive on the street ..every day with that cam.. Or should I take this one back and get something else.
Here are some options.
#1 Lift: .595/.595 Dur@.050: 242/242 LSA: 112
#2 Lift: .595/.595 Dur@.050: 231/231 LSA: 112
#3 Lift: .581/.581 Dur@.050: 224/224 :SA: 112 or 114
Any sugestions ?
Thank You
Old Aug 18, 2004 | 07:04 PM
teke184's Avatar
Re: Another...Camshaft question
i think you'll need a really high stall and a good tune in order to drive it on the street...
possible yes...
Old Aug 18, 2004 | 10:40 PM
LSUxBlake's Avatar
Yeah, although that cam isn't too terrible on lift. The duration is really pushing it and is much more than what most people drive with on the street, especially with an auto. You'll also probably need heads to take advantage of what that cam has to offer. I'd get the 224/224 or consider another brand of camshaft before putting that big **** in.
Old Aug 19, 2004 | 12:11 AM
ram air camaro's Avatar
i would suggest,
gears 3:73 with a 3200-3600 stall
better valve springs
and a realy good pcm tune !
Old Aug 19, 2004 | 07:48 AM
CRZYPWR's Avatar
I have ported heads on the way...3800 stall... 4.10 gears,push rods and dual springs installed already. Tunning I have to pay $350 for that. So maybe that #2 would be not that bad than.. 595 lift with 231 duration.
Hey LSUx I see that Your camshaft has pretty close specs.. Do You drive it on the street often ? How is that going ?
Thanks a lot guys
Old Aug 19, 2004 | 09:57 AM
blazers's Avatar
I have a 224/228/114 0.578 lift w/M6. Drive very good on the street. Dyno numbers- 384/rwhp and 381/rwtq. Stock heads.
Old Aug 19, 2004 | 10:55 AM
SSCamaro99_3's Avatar
It will take a lot of work to have good driveability in an auto. You will have to change valvesprings often with that set up. I would say every 15k maybe 20k if you are lucky. I have heard of a Manley spring breaking at 19k on a .575 lift cam, and a Crane dual (I can't remeber mileage and lift) breaking in the last week.
Old Aug 21, 2004 | 02:17 AM
dist0rtion_69's Avatar
I think you're going to run into piston to valve clearance problems running that cam on some milled heads. Possibly even stock heads, but unlikely.. won't know til you test it tho
Peace,
Josh
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
