what gears to use
Old Aug 10, 2004 | 09:43 PM
nico z28's Avatar
what gears to use
i have 3.42 now,, what should i go to? adding catback, thermo, air foil, tb bypass, hypertech prog, msd coil, plugs, 8mm wires, need some help guys,, 3.73, 3.90 , 4.10. with lockers, help????????????????
Old Aug 10, 2004 | 09:53 PM
jchevy's Avatar
Re: what gears to use
I personaly would prefer a 3.90 over the 4.10 but you cant get one for the stock 10 bolt.
Old Aug 10, 2004 | 10:02 PM
n2ceptor's Avatar
DO you have an A4 or M6??? Is it a daily driver or weekend warrior????
Old Aug 10, 2004 | 10:04 PM
jchevy's Avatar
I assumed it was a m6 b/c of the 3.42.
If you plan on doing nitrous stay with the 3.42 or 3.73. Otherwise do the 4.10s
Old Aug 10, 2004 | 10:08 PM
nico z28's Avatar
so a daily driver is ok with 4.10's,, 6speed?
Old Aug 10, 2004 | 10:10 PM
n2ceptor's Avatar
If you are worried about gas mileage go with 3.73s', if not then 4.10s'....JMO
Old Aug 10, 2004 | 10:16 PM
truedualws6's Avatar
I have 3.73s and that is the max I would go with a daily driver. If you are
willing to compromise and will do enough 1/4 mile stuff to make it worth
while then 4.10s. Definately nothing more than 4.10s.
Old Aug 10, 2004 | 10:48 PM
slayer6x6's Avatar
I just did the 4.10s. I still have to get the speedo calibrated, and you can count on doing some suspension work too. First gear is pretty much useless after the gears.
Old Aug 10, 2004 | 11:22 PM
chrism400's Avatar
I heard that the 3.73 gear was stronger than the 4.10 because it had an extra tooth in the pinion. For an m6, go with the 3.73. For the racetrack, use 26 inch slicks.
Old Aug 11, 2004 | 01:31 AM
disco192's Avatar
If its an M6... then i say 4.10+. I dont understand why everyone with an M6 is scared to go high on the gears. The M6 with a 4.10 gear still gets better gas mileage than an A4 with 3.23 gears.
You do run the risk of breaking easier with 4.10 than with a 3.73. So if i were you, i would run stock gears until you can afford a 12 bolt... then i would step up to 4.11 or 4.88
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
