Rod Bearings job
Old Aug 10, 2004 | 09:15 PM
mb^'s Avatar
mb^
Rod Bearings job
hi guys;
how hard is it to do a Rod Bearings job
is there a read me or how-to sume were ?
ty for your help so much i have ever done a Rod Bearing job
Old Aug 10, 2004 | 11:41 PM
oil pan 4's Avatar
Re: Rod Bearings job
Well what engine is it for?
You will have to pull the engine out first of all.
Put the crank main cap on in the same position as you removed them same with the rods.
You should pull the heads and work on them while your at it, get new pistons maybe and at the least put new rings and hone the bores.
You will have to pull the crank out so do the main bearings too.
If you have a 2.8 3.1 or 3.4 I can tell you how to modify the main bearings so you get more oil to the rod bearings.
It goes on and on, it's a lot to do.
You will need an engine rebuild guide more or less.
It won't be simple you will need a lot of tools parts and seals.
Old Aug 11, 2004 | 10:07 AM
mb^'s Avatar
mb^
o god this is going to be fun then
it has to be a 3.1 or 3.4
sry to ask but do you have a pic of the crank main cap
and do you kown were i can get a good rebuilt kit wth the **** i would like
i'm going to be puting a v8 in so theres no neeed to do over work
Old Aug 11, 2004 | 01:40 PM
oil pan 4's Avatar
You could get a rebuild kit from a place like napa and geta cam from summit or a crane dealer.
I don't have a main cam pic.
Old Aug 11, 2004 | 04:30 PM
mb^'s Avatar
mb^
i'm geting it from here
http://www.newengineparts.com/
god its to bad i do not kown how to put in Oversize **** in.......i would like to go .040
Old Aug 12, 2004 | 09:19 AM
oil pan 4's Avatar
You have to thake the engine to a machine shop and have the cylinder s bored. But you only realy need to bore them if there damage or your doing a preformance build up. If there not tore up you can just hone them and put them back to gether,
Old Aug 12, 2004 | 05:55 PM
mb^'s Avatar
mb^
Cool Re: Rod Bearings job
o ok so your saying that .030 or .040 would go in to it wth out boreing it ( if so that would be good)
Old Aug 13, 2004 | 01:38 AM
Ace_437's Avatar
No, he's saying you'd have to bore the cylinders out by either .030 or .040 inches. You can't just stuff the oversized pistons in, they won't fit.
Old Aug 13, 2004 | 12:33 PM
mb^'s Avatar
mb^
ya i was going to say thats not how it in the 300zx lol
carl.froehlich
Mar 13, 2015 12:38 AM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
Bill'sWS6
Aug 5, 2002 01:00 PM
