put hurst shifter in and getting some noise
Old Aug 5, 2004 | 09:20 PM
bad94ss's Avatar
i put hurst shifter in last week, now it is making some sort of noise when i in gear. does not matter what gear i am in, but the noise go away if i press to its place(if i am in 3rd, i keep press up the noise go away. in 4th i press down and noise go away)
is that normal???
Old Aug 5, 2004 | 09:33 PM
slayer6x6's Avatar
Re: put hurst shifter in and getting some noise
What kind of noise is it? Squeak, rattle, grind?
Old Aug 5, 2004 | 09:34 PM
Mike94ZLT1's Avatar
totally normal. If you look at the stock shifter there's a big rubber bushing between the actual shifter and the shift handle. That absorbs vibration and stops the noise. Without that bushing there, you hear all kinds of drivetrain noise. If it annoys you go to the hardware store and get some rubber washers to go between the shifter and the handle, the two bolts at the bottom. Won't solve the problem, but they should help some. You get used to it after awhile. It's not hurting anything.
Old Aug 5, 2004 | 10:34 PM
StreamlineZ28's Avatar
If it is the same noise i get, some shifter companies recommend you spary the ball with a teflon spray. that should take some of the noise away.
Old Aug 5, 2004 | 10:35 PM
bad94ss's Avatar
thanks man, that helps me a lot
Old Aug 5, 2004 | 11:02 PM
Mike94ZLT1's Avatar
Lol make sure you specify the ball on the end of the rod that goes in the trans, I can imagine some people spraying their shift *****!
Old Aug 5, 2004 | 11:21 PM
yeah not the shifter ****
Old Aug 6, 2004 | 08:59 PM
Kevin97ss's Avatar
Also, if its the billet plus model make sure the shift stops are adjusted correctly. If the stick is in constant contact with the stop while in gear it can cause problems as well as excessive noise.
Z28-50
Parts Wanted
Feb 21, 2015 09:00 PM
Jazsun
Dec 29, 2014 12:14 PM
slocody
Feb 10, 2003 01:04 PM
redz_02
Jul 24, 2002 09:42 AM
