will the tires I want rub?
Old Aug 2, 2004 | 06:21 PM
crasher88's Avatar
I got a 94 3.4L camaro right now I have the stock 215/50/16 on all four tires. I want to put some 245/60/16 all the way around. But I'm concerned that with the higher profile tires that when I'm turning the front wheels they will rub on the wheel well or rub on something. Does anyone have these on their camaro and not rub?
Gary
Old Aug 2, 2004 | 09:36 PM
Re: will the tires I want rub?
Gary
You might want to go back and check your sizes. The base tires on the V6 Camaros was a 215/60-16. That tire is about 25.7" diameter. The stock tire on a Z28 with the Z-rated tires was a 245/50-16, also with a diameter of 25.6-25.7". In effect, both tires are the same diameter, the 245 is just a little wider. And, since they were the stock tires on the Z28, there is no reason they would rub on your car, assuming you have the same size, and offset wheel as the Z28 - 16x8" 55mm offset.
If you really mean you want 245/60-16 tires, you will have a problem, because a) Tire Rack doesn't list any tires in that size; b) if they did, they would be almost 2" larger in diameter than you original stock tires, would definitely rub, and would slow your car down quite a bit, because that large a tire would have the same affect as going to a numerically lower rear axle ratio.
Old Aug 2, 2004 | 09:45 PM
crasher88's Avatar
I kid you not they are 215/50/16 I do'nt think they are stock as what came on the car from the factory but thats what was on there when I bought the car. So the biggest I could go is 245/50/16 all the way around?
Old Aug 2, 2004 | 09:54 PM
There is also a 255/50-16 that will work on an 8" wide wheel. That's about it for 16 inchers.
If you are running 215/50-16, and no one corrected your speedometer, it might be off a bit. A 215/50 is only 24.4" diameter. Your speedo will be showing about 5% more MPH than actual speed, and your odometer is racking up 1050 miles for every actual 1000 miles driven.
2QUIK6
Sep 17, 2016 02:31 PM
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
colts0455
13
Aug 7, 2015 09:15 PM
Slayer
Jul 4, 2015 03:06 PM
