Retard timing with a resistor in the IAT circuit ?
Old Jul 22, 2004 | 11:45 PM
Kris96WS6's Avatar
I seem to remember there being talk about using resistor in the IAT circuit to retard timing (by reporting false temp, eg hot intake air temp the PCM will retard timing). I figured this could be an easy and cheap way to pull a little timing before hitting the juice by wiring a switch into the circuit that would "engage a resistor" just when you needed it. Anyone ever do this or have an idea of how it can be done. I have datamaster so I could test it to see if it actually was pulling timing. Any thoughts appreciated.
Old Jul 23, 2004 | 06:16 PM
BILLJ's Avatar
Re: Retard timing with a resistor in the IAT circuit ?
I know it works with the LS1. I can post the pic on how to do it if you still want to try.
Old Jul 23, 2004 | 06:43 PM
Kris96WS6's Avatar
Yes, please post the pic.
If I investigate and find that the IAT sensor is the same part or outputs the same signal / voltage range in the LS1 as it does in the LT1 then it should work. Regardless, it would be interesting to see the LS1 solution.
Old Jul 25, 2004 | 09:08 AM
BILLJ's Avatar
K, I will find it and get it up or out to you.
Feffman
Oct 9, 2015 05:42 AM
grabbem88
Feb 13, 2015 03:09 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
nophix
Nov 30, 2014 10:26 PM
