Need some ideas...
Old Jul 21, 2004 | 08:40 PM
flusz28's Avatar
Need some ideas...
Okay i bought a used s-trim and its install just need to tap a hole in the oil pan and connect up the lines. my question is that - the guy i bought it off of never sent me the vortech coil relocation bracket. so i made my own, only problem is that the maf sensor won't fit in the stock location cause the coil plugs are in the way. i want the maf in the stock location. this is the first question. do i just cut the length of the black tubethat connects to the vortech shinny elbow so my maf will fit??? heres the other question-- since the coil is in the road i want to mount it somewhere else. one i will need to added some length to the wires i know that. but where could i mount the coil else where? also where could i buy just one plug wire that i could use for the coil and ignition? Thanks
eanhl2004
Apr 4, 2015 12:01 PM
jrj274
Jan 25, 2014 05:26 PM
jrj274
Jan 24, 2014 02:43 PM
Usmcadele
Dec 17, 2011 01:46 PM
TheHeadFL
Aug 8, 2011 05:33 PM
