how do i bleed ls1 slave????
Old Jul 15, 2004 | 04:50 PM
1mostlystockz28's Avatar
i broke my tranny a couple of weeks ago and while i was pulling it out it poped the rubber seal in the slave and fliud started to leak out of it. do i need a new slave or is this one ok? and if its ok how do i bleed the system? any help appreciated
Thanks Jason
Old Jul 15, 2004 | 10:56 PM
There is a hex-shaped bleeder tube that sticks out of the edge of the bellhousing where the braided hose goes into the bellhousing. It is on the drivers side, pointing upwards.... a little awkward to get at.
Old Jul 17, 2004 | 01:05 AM
coogsLS1's Avatar
good luck, definately a PITA. pump the pedal a million miles an hour while that valve is open. Wait for a steady stream. they make some tool that helps you with it.
I also heard that the front end needs to be up higher than the bottom end because of the position of the master cylinder. Good luck, definately challenging.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
Hal Fisher
Sep 30, 2015 09:03 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Z Power
Sep 19, 2015 11:19 PM
