Rag Joint
Old Jul 10, 2004 | 05:19 PM
1msfyter's Avatar
Rag Joint
Can someone explain what it is? I know its part of the steering,but what is it exactly? I have seen a ragjoint kit that helps steering better for $32. Will it help?
Old Jul 11, 2004 | 02:07 AM
kgkern01's Avatar
Mine had about 150k on it and 9 years, so I went ahead and did the Ragjoint eliminator. Not hard to do, plus seemed like a slightly more resposive/feeling in the wheel. Although I did the 35mm solid sway at the same time. I would recommend it, especially for the price and short amt of time required to change it. A grinder is great for removing the stock rivets.
Old Jul 11, 2004 | 02:38 AM
Alex94TAGT's Avatar
The rag joint is located on your steering intermediate shaft (the shaft on the driver's side of the engine bay that connects between the steering wheel and the rack-and-pinion). The rag joint is enclosed in a plastic shield.
I too have done the rag joint eliminator. It did not produce an incredibly drastic change on my car, but for $30, I'd recommend it.
If you do decide to do this, have fun with the rivets. They wont come out without a fight.
Old Jul 11, 2004 | 03:08 PM
Jon A's Avatar
This should give you a fairly good description:
http://frrax.com/rrforum/index.php?act=ST&f=3&t=327&
Victor Lamb
Aug 26, 2017 02:52 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
hcarrickz3
Jul 21, 2015 08:46 AM
blac94Z
15
Mar 2, 2015 12:00 PM
RobK
12
Oct 29, 2002 07:24 PM
