NX N20 pressure guage.
Old Jul 9, 2004 | 04:23 PM
94NDTA's Avatar
Can I use this in the dash? How can I hook it up there? If not, what is the cheapest route of getting a guage for the N20 up there. I would rather not buy another gauge, but if I HAVE to, show me the light!
Old Jul 9, 2004 | 05:05 PM
96speed's Avatar
You would need some nitrous (high pressure) line to feed the gauge. Otherwise you'll need an electric pressure gauge (big bucks).
Ryan
Old Jul 9, 2004 | 05:22 PM
94NDTA's Avatar
Why is it I have never seen anyone use their supplied NX pressure gauge in the cockpit? How would I hook this up? Could from the solinoid?
Old Jul 9, 2004 | 09:22 PM
94NDTA's Avatar
Anyone...reason why they aren't used?
Old Jul 10, 2004 | 01:11 AM
96speed's Avatar
Because you'd have a nitrous line pointing at your face .
Electrical is just expensive. That's the only drawback.
Ryan
Old Jul 10, 2004 | 09:15 AM
94NDTA's Avatar
But I see people with mechanical gauges all the time in their cab, I was just wondering why no one uses the gauge that comes with the NX kit.
Old Jul 10, 2004 | 02:20 PM
slp223's Avatar
there is no lighting on them so you cannot see them at night.
Old Jul 10, 2004 | 04:27 PM
94NDTA's Avatar
What all would I need to hook it up in the front of the car?
Old Jul 11, 2004 | 01:34 PM
slp223's Avatar
a few fittings and some line.
Old Jul 11, 2004 | 10:50 PM
If you are going to mount a mechanical nitrous pressure gauge inside the car, be sure to use the correct "flow limiting" fitting at the main nitrous line connection. This is a solid fitting with a very small diameter hole drilled in it, to prevent excess nitrous flow into the passenger compartment, in the event the line or the gauge breaks.
AutoMeter #3277 flow restrictor
KYWes
Jun 14, 2022 06:52 AM
canuck94z28
Aug 19, 2015 05:50 PM
karpetcm
Aug 14, 2015 03:02 PM
350350
14
Aug 11, 2015 12:03 PM
Alibi
Aug 1, 2015 07:50 PM
