Help with ignition box settings
Old Sep 23, 2002 | 03:43 PM
Loadre's Avatar
Aight, my mallory is on the way. Had a few questions. What's the stock rev limiter set at? What're '94 Z shift points set at? Should I set the mallory rev limiter 100 RPM below the PCMs then the window switch another 100 below that? I shouldn't put mallory's limiter right on with the PCMs should I? Basically what I'm asking is what the window switch should shut off at and where mallory's limiter should go.
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
