rear end swap
Old May 22, 2004 | 09:06 PM
lt1hatesme's Avatar
rear end swap
alright so i got my new rear end, (new to me) its a 3.23 non TC from a 2001 TA. complete from caliper to caliper, brake lines, LCAs, sway bar, shocks and springs, all for $170.00.
so im gonna put it into my car probably tomorrow and if anyone else has swapped one please tell me everything i need to know.
im going to have the rotors turned at the shop tomorrow and other than that, i was just gonna bolt it up, that mess is heavy. is there anything else i should know?
also, how long will a swap like this take?
BTW this is for the 94
Old May 22, 2004 | 09:12 PM
Fuels94TA's Avatar
It took me about 5 hours with another hand to help.
Vinny
Old May 22, 2004 | 11:21 PM
lt1hatesme's Avatar
ttt
Old May 23, 2004 | 04:41 PM
lt1hatesme's Avatar
lemme guess, nobody else has done a rear swap?
Old May 23, 2004 | 09:50 PM
Eds69s's Avatar
I have not swapped any rearends on the latest camaros but have changed a few on the 91 models. I don't think there is much difference. I went from drum brake rearend to disc. and posi unit in a 91 Firebird. No problems! Just take your time and make sure everything is tightened. I did the swap myself and took about 31/2 hours. You may want to spray penetrating oil on the bolts ahead of time. This may help. Good luck. Ed
Old May 24, 2004 | 11:07 PM
lt1hatesme's Avatar
ok well i just did the rear swap... and aside from breaking off rusted bolts, it was rather easy. i have a few questions tho...
1. the rear was a 3 channel ABS but the connecter for the abs wasnt the same size... so as of right now it's disconnected. and the pedal feels like crap and my ABS INOP and BRAKE lights are on. what can i do to fix this?!?!?!?
2. the new rear came with springs and some rubber things that go on top of the springs, well they are way thicker than what was already on my car, and now the cars *** sits up a couple inches higher. can i take these off, or should i put the stock ones back? thats all the questions for now but im sure i will have more before tonight is over. thanks for the help.
Old May 25, 2004 | 01:23 PM
lt1hatesme's Avatar
where are all the experts at?!?!
Old May 25, 2004 | 01:55 PM
I have an online procedure for swapping in a 12-bolt... the basics will be the same:
http://members.aol.com/InjuneerZZ/Strange12.htm
Shouldn't take more than a few hours. I did it alone, laying on my back on the garage floor in an afternoon.
Old May 25, 2004 | 05:46 PM
lt1hatesme's Avatar
thats a pretty sweet article but can you answer these questions for me?
thanks a bunch!!!
Old May 25, 2004 | 08:15 PM
lt1hatesme's Avatar
ok well i just took the abs sensor off my old rear, and put it on the new rear, and now my ABS INOP light went out, but my BRAKE light is still on, and the brake pedal feels mushy still...although better than without the ABS sensor.
what can i do to get this BRAKE light away and get my pedal feel back to normal? should i bleed the rear brakes? is that even possible? i lost a little fluid from the brake line and i replaced it under the hood but should i bleed them as well? also is there some kind of adjustment im overlooking? the hand brake cables were very straight forward i dont see how you can mess that up
Old May 25, 2004 | 11:24 PM
If you opened up the brake lines, you have to bleed the system. The "BRAKE" light is coming on because you have uneven pressures in the front and rear braking circuits.
Old May 26, 2004 | 03:09 AM
lt1hatesme's Avatar
would that be due to the air in the brake lines or to the fact that my rear brakes are now bigger than my front brakes?
i took the rear from a ls1 fbody and i swear the rear brakes are the same size as my fronts.
Old May 26, 2004 | 03:15 AM
AL SS590 M6's Avatar
Moderator
Air
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
