Am I doing something wrong?? TPS voltage
Old May 11, 2004 | 11:03 PM
Robs97Z28's Avatar
With key on , engine off at idle volt meter is reading -4.41 and at WOT I'm seeing .51.. I have the meter + red wire from the meter back probing into the blue wire on the tps. I have the - black wire from the meter back probing the black wire on the TPS. Is this correct? I'm doing something wrong? If so, what is the correct way of do this?
Old May 12, 2004 | 11:12 AM
blacknight's Avatar
http://www.ls1camaro.net/sections.ph...ticle&artid=26
Old May 12, 2004 | 01:32 PM
Check the harness completely.
Measure resistance of black wire to a chassis ground to confirm it is a good ground. Confirm no voltage on this wire.
Measure gray wire to ground, to confirm it is supplying +5V reference.
Then check the blue wire voltage to black wire, and to chassis ground.
Not sure what the LS1 TB bump stop mod has to do with an LT1 TPS sensor????
Old May 12, 2004 | 07:25 PM
Robs97Z28's Avatar
Thank you, Fred. I will check this out after dinner. I will let you know what I find. Rob
Old May 12, 2004 | 09:12 PM
Robs97Z28's Avatar
ok, this is what I found. I guess I need to take a little more time testing and making sure I get a good connection.
black to ground: 1.3 omhs
black volts: .33
gray volts: 5.03
bule to ground: .623
blue to black: .591
wot: 4.49
seems it is in the ball park
truecontr3
Oct 11, 2015 09:30 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
