Wiring in a capacitor
Old May 10, 2004 | 05:12 PM
KillerTA's Avatar
I have a capacitor that has no manual with it so I'm not positive on how to wire it.
I wired i inline with the power and ground cables so basically I just cut the cables and hooked up the wires to the capacitor. Will that work?
Old May 10, 2004 | 05:16 PM
Knowklew's Avatar
you have to load it first...
Old May 10, 2004 | 05:34 PM
KillerTA's Avatar
explain please
Old May 10, 2004 | 09:39 PM
Mr.Smith's Avatar
basically that means u have to add a resistor , i believe. there is a equation to figure out what how high of a resistor you need, but i can't remeber it, prolly something you could google tho...
Old May 11, 2004 | 06:27 AM
97FormulaWS-6's Avatar
The + of the cap gets connected inline with the Positive cable. The - side gets wired to ground.
You need to "charge" it with a resistor, or you're going to get one hell of a spark when you go to connect to your battery or fuse.
Old May 11, 2004 | 12:34 PM
KillerTA's Avatar
Well, it's already hooked up and I didn't get any sparks so I should be ok, right?
It is a used one that had been in a car before but it's been sitting in my basement for about 2 years.
What do you mean by a resistor?
Old May 11, 2004 | 02:10 PM
It depends, did you hook it up inline, or as I said to wire it?
A resistor, a simple electronic component; Used to limit current...
Old May 11, 2004 | 03:18 PM
KillerTA's Avatar
I hooked it up inline.
Old May 11, 2004 | 03:56 PM
It's not doing a damn thing for you then...
Old May 11, 2004 | 06:08 PM
KillerTA's Avatar
So I'll just have to ground it then and it'll work?
Old May 11, 2004 | 07:23 PM
Wire it as follows, but be careful, it can spark...
+ from main power wire to + on Cap
+ on Cap to + on Amp
- on Cap to Ground
- on Amp to Ground
If you are going to buy a resistor to charge the cap first, (1K ohm, 1/4W from radioshack, or 12V light bulb), then do the following:
+ from Main power wire to + on cap
- Cap to Resistor to Ground (This is where you charge the Cap, make sure you have the battery connected when you do the resistor/ground; after it's charged, disconnect the battery then continue)
Amp - to Ground
Cap + to Amp +
THen re-connect the battery, and you should be good to go. You can skip the charging, but it can/will spark pretty strongly.
Old May 11, 2004 | 10:23 PM
KillerTA's Avatar
Thanks!
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
