How tight should lug nuts really be tq to?
Old May 10, 2004 | 10:06 AM
94 CAMRO Z28's Avatar
Question How tight should lug nuts really be tq to?
Just curious since I've always just "snugged them up". But now that I have ET streets that I put on each time at the track and with working on my friends stock car we are pulling tires all the time. In highschool I think we would put them on at 100lbs. Is that about right? My reason asking is Im thinking about getting a cordless impact for use at the track and I would like to know how big of one I need. thanks
Aaron
Old May 10, 2004 | 10:30 AM
Red5.7's Avatar
I think it is 100 ft lbs, I swear I remember seeing that in the manual as I flipped through it before.
Old May 10, 2004 | 10:38 AM
PatriotTA's Avatar
Its 100 ft-lbs. I don't torque mine, though. I just use my impact wrench.
Old May 10, 2004 | 11:10 AM
Red96Lt1's Avatar
Mine are at 100 ft lbs.
Old May 10, 2004 | 12:19 PM
rncotton's Avatar
Yup -- 100 Ft-Lbs ... which ain't much more than finger tight.
Old May 10, 2004 | 01:37 PM
Lower's Avatar
I'd guess you're torque wrench is broken then, because 100 ft/lbs, is really darned tight -100 in/lbs would be a touch more than finger tight however, but I sure hope you aren't using 100in/lbs for your lugs!
Old May 10, 2004 | 02:42 PM
PatriotTA's Avatar
Boy, would that be a bad day
Old May 10, 2004 | 03:03 PM
For alloy wheels with conical lug nuts, 100 lb-ft is the norm. For a shank style lug, with a washer, like the Welds use, its 60 lb-ft. Nothing wrong with removing the lugs with an impact wrench, or with running the nut up to the wheel with the impact wrench, but final tightening is best accomplished with a torque wrench.
Old May 10, 2004 | 03:35 PM
Chrisz24's Avatar
I made that mistake a few months back and broke a stud.
I now have a torque wrench, 100- is it feet or inches? I'm not sure, I'll be so embarrised if I break another stud or have a wheel fall off
Old May 10, 2004 | 11:46 PM
bski224's Avatar
i have weld draglights and WELD calls for the Lug nuts to be 70-80 lbs i got mine @ 75. Its also suggested to re tighten them after a bunch of miles.
IndyZman
Oct 22, 2015 02:17 PM
tdigger9899
Sep 7, 2015 10:56 AM
Dams76
Aug 20, 2015 08:28 AM
TGGodfrey
Aug 17, 2015 08:43 PM
Boss002
Jul 24, 2015 10:47 AM
