Hesitation??
Old Apr 21, 2004 | 11:14 PM
99blackz99's Avatar
Hesitation??
Well I just installed LT's and changed plugs and wires, now when I hit the gas no matter if its easy or if Im stomping it there is a slight hesitation, now I dont know if it was doing it before header install or not since this has been pretty much the first nice weather since winter. Now I was thinking it might be a couple of things and I need everyones experiance to tell me if either is right. First I was thinking it might be a spark plug wire not on, but it idles just fine, I dont know how bad it would runif only one wire wasnt on. Second I was thinking it might be the fuel filter, it has 30,000 on it and I put 15,000 on it myself and never changed the filter, and I do drive it occasionally until the fuel light comes on which I know is bad but with gas the way it is I try to wait til it goes down a bit but I do always put in 93 oct. and never anything less. So hopefully some one else has had this prob and can help
One more thing, I hear people on here saying that after long tube install the car runs funny until the computer reprograms itself, well mine never ran funny, but I never disconnected the battery or reset the computer thruout the install, should I.
Old Apr 23, 2004 | 09:30 PM
99blackz99's Avatar
So no one has had hesitation problems??
Old Apr 23, 2004 | 09:52 PM
ryan1488's Avatar
you mean a slight hesitation when you mash it and the car kicks down a gear? i think we all have this prob. kinda annoying. im not sure if programming would be a fix or not but i bet it would.
Old Apr 23, 2004 | 11:35 PM
99blackz99's Avatar
No my car is a manual, its when you hit the gas and the car pauses for a second. And I climbed on top the engine and was able to reach that last spark plug wire and make sure it was in, so thats not the problem.
Old Apr 24, 2004 | 01:13 AM
chpmnsws6's Avatar
check your wires! for some reason, these cars run fine on 7 cylinders but they kinda studder when u give it some gas at a low RPM. keep us updated
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
