Any grinding necessary for Pro Stars to fit an LT1?
Old Apr 13, 2004 | 06:51 PM
PatriotTA's Avatar
Just like it says. Do you need to grind the wheels or the brakes at all for a set of Pro Stars to clear the brakes on an LT1 car? I heard something about needing to grind with Weld wheels.
Old Apr 13, 2004 | 11:46 PM
97TA-WS6-Con's Avatar
Yup. Grab an angle grinder and do some fairly serious damage to the fins on the caliper. Make sure you take off too much rather then to little.
Old Apr 14, 2004 | 06:32 AM
PatriotTA's Avatar
Do you have any pics of the caliper after you ground it down?
Old Apr 14, 2004 | 12:03 PM
Assume you are talking about the back wheels/brakes. Yes, grind the caliper fins off, mainly on the "corner". See pic below.... not real clear, but should give you an idea.
http://cjcfo.fbody.com/members/injun.../DCP03113b.jpg
In the front, you typically need a 1/4" of 5/16" spacer so the wheel will clear the spring clip that holds the pads in the caliper and the big horizontal bar on the steering knuckle that supports the calipers/pads.
DirtyDaveW
Dec 1, 2016 05:37 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
siguy
Nov 27, 2014 10:07 AM
ChrisFrez
Nov 23, 2014 10:33 AM
Javier97Z28
Jul 24, 2002 08:13 AM
