kPa?
Old Apr 12, 2004 | 03:12 PM
jdizzell's Avatar
kPa?
I know that kPa is a unit of measurement of pressure by the pcm, but what i dont understand is what the k stands for? I know that Pa(pascal) is a unit of measuement of atmoshere pressure, 1 atm=101,325 Pa, so why is 100 the max? How does the k change the unit measurement?
Old Apr 12, 2004 | 05:52 PM
96TurboTA's Avatar
k stands for kilo. 1000Pa = 1kPa. So divide the Pa by 1000, and you get roughly 100kPa
Old Apr 12, 2004 | 08:07 PM
jdizzell's Avatar
That clears it up, but why didnt gm set the kpa to 101.325 for a more accurate reading? Or is 100 kpa just what the scanners use?
Old Apr 12, 2004 | 09:27 PM
There is no "limit" of 100kPA.... a 1bar MAP sensor will generally output the voltage (5.0) that corresponds to over 100kPa. I've seen some scanner data logs where the barometric pressure (BAR) is reported at up to 103.7kPa. You generally do not see many readings over 100kPa for the MAP reading, since there is always "some" pressure loss through the filter, ductwork, throttle body, etc.... There's nothing magic about 100kPa, except that by definition it is "one atmosphere" in the metric system, which sets the standard atmosphere at the equivalent of 14.5psia, rather than the 14.7psia used in the English system.
Old Apr 12, 2004 | 09:36 PM
jdizzell's Avatar
Injuneer, that clears it up even more!!! I didnt even think about the fact the MAP sensor would just put out 5.0v for anything over 100kpa.
Old Apr 14, 2004 | 12:43 PM
The calibration chart I have seen shows 4.9V = 100kPa.... so you would get a slightly higher reading at 5.0V.
Old Apr 14, 2004 | 04:33 PM
SMOKNZ's Avatar
I do!! I see 103.7kpa under WOT, but I'm adding a little air to the mix!
Bigtoyz97
Sep 21, 2015 01:44 PM
Chris 96 WS6
Advanced Tech
24
Apr 22, 2004 01:26 PM
Schurters LT1
Oct 10, 2003 10:02 PM
96z
Apr 6, 2003 01:08 PM
canbaufo
Mar 19, 2003 03:19 PM
