DTC Code 36 popped up..
Old Apr 3, 2004 | 11:29 AM
darkangel95's Avatar
I was out driving my new 95 to check the o2's and KR on my scanmaster. I ran it once and the o2's looked good at around 900 the entire time and and KR stayed at 0.0. This was on a spirited run from about 0-60, then I parked my car and when I came back and started my car up the o2's started at 500 and the gradually went to 004-010. Then I went and floored it again and ran it up to about 60 again and the o2's were acting strange and the KR was much higher at around 10.0 and then a DTC code 36 popped up. I know that this is a high resolution and/or muliple low resolution misses. My question is what could this be and what could cause it?
Thanks for any help.
Old Apr 3, 2004 | 03:34 PM
Lyle A's Avatar
It can be an open, a short to voltage, a short to ground, or a defective sensor in the distributor. Clear it and hope it doesn't come back. If so, it may be necessary to replace the opti.
Old Apr 3, 2004 | 09:23 PM
Is there any way that you can tell which one it is?
Old Apr 3, 2004 | 10:39 PM
Lyle A's Avatar
Well, I'm feeling lazy not wanting to type much so here is the steps from the manual . And use this diagram for reference. You have to register to view the pic. Copy it to your computer and print it. I don't have a scanner but I do have a good camera so the pic is very high res and readable.
Old Apr 4, 2004 | 12:06 PM
Thanks alot man, I will clear it and see what happens. It hasn't come back yet.
Ohh yeah I couldn't view the first link..
Old Apr 4, 2004 | 03:40 PM
Lyle A's Avatar
Register at the site then you can view it.
95z_28_camaro_4_Ivan
28
Jul 23, 2015 11:55 AM
LingenfelterZ28
Apr 25, 2015 10:24 PM
LingenfelterZ28
Apr 24, 2015 02:00 PM
dreamer1q
Aug 20, 2002 11:19 AM
91Bird305
Aug 5, 2002 01:39 PM
