To O-ring or not to O-ring, that is the question
Old Mar 29, 2004 | 01:02 PM
prisoner881's Avatar
At what point does it become beneficial for a pump-gas turbo motor to go with O-rings? Are there any disadvantages (aside from machining costs) to going with O-rings?
Old Mar 29, 2004 | 01:33 PM
sleeperz28's Avatar
Re: To O-ring or not to O-ring, that is the question
A pump gas turbo motor should not need o-rings. A good pair of bolts should hold the heads down to about 20psi. In my experiance I have not seen a case for a street car to run 0-rings on a camaro
Old Mar 29, 2004 | 02:15 PM
Re: Re: To O-ring or not to O-ring, that is the question
Assuming for a moment that O-ringing the heads/block were free...would you still do it anyway on a street motor? I mean, are there any advantages at all to doing it at under 20psi?
Old Mar 29, 2004 | 08:51 PM
sleeperz28's Avatar
With a good tune you should not have any problems blowing head gaskets. When you decide to o-ring the block, I believe the only gasket you can use is copper. Copper has a tendency to leak. If you do a search on this topic it has been talked about many times.
Old Mar 30, 2004 | 02:45 PM
JZ 97 SS 1500's Avatar
Stick to non-oringed heads and just use ARP studs or ARP bolts even. They have been proven at 20psi for the bolts and the studs above that.
Jose
Old Mar 31, 2004 | 02:21 PM
Kevin97ss's Avatar
To run an o-ringed block you should use copper head gaskets and they are very hard to seal up around the water jackets.
Fortunetly there is newer/better technology out there. Alot of race cars including ProMods are now using MLS head gaskets. MLS or Multi Layered Steele seal better than copper/o-ring set ups and dont require any machine work. It does require though that the block and heads are flat and extremly clean. So overall its cheaper and better and proven.
Kevin
grabbem88
Mar 25, 2015 12:09 PM
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
