Problems After installing Mcleod Clutch
Old Mar 27, 2004 | 12:50 AM
lt1_forever's Avatar
Unhappy Problems After installing Mcleod Clutch
Well i installed my mcleod a week ago and went to drive it and it started making a loud popping clunking sorta sound when letting out the clutch in 1st. Well i thought at first i might have been the headers i installed at the sametime(also having problem w/ headers). So when i went to fix my problems with the headers i started the car up w/ the clutch in and "nothing" it seemed fine except for the car running like s**t because it misfiring and throughing the code P0300. So i let the clutch out and i start to feel like something was bumping the tranny or something, put the clutch in again went away. Let it out samething. The only thing i could think of was maybe the clutch fork, because everything went in fine and the tranny just slid right in. So i raised the car back up and took a look at the everything visually to make sure everything was bolted in and hooked up. The only thing i saw disconnected was the reverse lockout soleinod. But i went ahead and took off the tranny again to take a look. Everything looked fine(i didnt pull off bellhouse or PP etc) no rubbing off clutch fork or anything. So i don't know what to do, i'm stumped???
All help is appriecated.
Old Mar 27, 2004 | 01:40 AM
Blue89Bird's Avatar
it's chatter, its just what hi grab clutches do
Old Mar 27, 2004 | 02:12 AM
how loud is clutch chatter?
Old Mar 27, 2004 | 06:25 AM
97Camaro007's Avatar
It's not that loud.....what kind of headers do you have? If they are hooker long tubes or equvalent then you might have to cut the frame a little bit where they are hitting.....i think that i had to make a little cut so that the headers would clear the frame......because it would make a lound bang everytime i changed gears and when i took off.....
Old Mar 27, 2004 | 09:31 AM
well i have mac midlengths with OR y-pipe. Do those usually hit?
Old Mar 28, 2004 | 12:40 AM
I'm not sure about the mid length's....I've never owned a set....maybe someone else on here can help though
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
siguy
Nov 27, 2014 10:07 AM
slothgrant
Aug 22, 2002 03:01 PM
