Can a OBDII be reflashed to become a OBDI?
Old Mar 22, 2004 | 05:02 AM
BlackDog's Avatar
We put a 97 LT1 motor into a 68 Camaro, the car will start and run for about 30 sec. then die. The fuel pressure is good.
I figured changing the pcm to a OBDI would be the cheaper way to go, instead of buying o2 sims and scanning software etc.
Can an OBDII be reflashed to an OBDI?
Scott
Old Mar 22, 2004 | 08:33 AM
Highlander's Avatar
No... its a different protocol to flash it.. So you would have to buy ls1edit to do it... The SPS will not flash the obdii pcm to obdi for being a different way of flashing the PCM...
Either buy ls1edit or... obdi conversion... the obdii controls better the converter, specially if high stall.
Old Mar 22, 2004 | 04:26 PM
BlackDog's Avatar
That's what I thought, thanks Highlander.
Scott
Aug 7, 2015 08:52 AM
aj2494
Mar 12, 2015 10:17 PM
SnkEatr
Feb 9, 2003 09:56 PM
96z
Feb 6, 2003 03:23 PM
LTOne4Fun
Sep 1, 2002 05:31 PM
