Unplugging lock up
Old Mar 20, 2004 | 02:26 AM
Don't Look Back's Avatar
Unplugging lock up
I'm having a real bad stumbling problem that my cousin/mechanic believe to most likely be the lock up on the converter. He suggested unplugging the lockup to determine if this is the culprit, and if it is, just to leave it unplugged. How much damage can running the converter without lock up do to the trans?
Old Mar 20, 2004 | 06:18 PM
12SCNDZ's Avatar
First of all, the plug that goes into your transmission controls the shifts and pressure also. You'd have to know which wire to cut. If you disconnect the TCC, you'll get a "SES" light.
Overdrive transmissions usually need lockup to keep from overheating. My 700 (hydraulically controlled) has a non lock-up converter in it, but it has an aftermarket valve in the pump that takes the place of the lock-up valve to help keep it cool.
Frank
All-Trans Transmissions
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
autoxr166
Sep 25, 2015 04:21 PM
z28cam1993
Sep 9, 2015 04:08 AM
