‘00 z28 no ASR ?!!
Old Mar 12, 2004 | 10:46 AM
roadkillZ28's Avatar
Unhappy ‘00 z28 no ASR ?!!
This regarding the acceleration slip regulation (ASR).
My A4 z28 is model 2000. I am curios and concern why my car is not all equipped with this type of gadget ASR.
If the aim of this ASR is somewhat to regulate or stabilize the car while turning in high speed...., why I don’t have it ??? are there restriction in using this ASR for cars in the U.S., Canada, European countries and ME (middle east region).
Old Mar 12, 2004 | 10:55 AM
95GRNZ's Avatar
Are you the first owner of the car?
If my memory serves me correct, ASR was just another option, so it did not automatically come with the car.
TS
Old Mar 12, 2004 | 11:04 AM
bombd84's Avatar
Ahhh, I would be kinda thankfull if I were you. Whenever you turn the car on, it is automatically activated unless you buy like a 65$ piece to plug into it. It doesnt exactly do a whole lot for handeling.
Old Mar 12, 2004 | 11:26 AM
02RedZ28's Avatar
ASR has nothing to do with turning at high speeds. ASR is traction control, and a lot of people see it as a nuisance.
Old Mar 12, 2004 | 12:11 PM
DanBUCF's Avatar
100% Correct.
My car didn't come with ASR, and I am thankful for that everytime I drive it.
Old Mar 12, 2004 | 12:28 PM
Ken S's Avatar
its simply traction control for straight lines.. It may help in the turns a little, but its really meant for straight lines, since it doesn't take in consideration what happens if you let off the power in the middle of the turn.
Doesn't do anything for handling, in fact probably will make you slower since it'll cut back the throttle when you power out of a turn.
One bright side of ASR equipped cars.. If you ever need a beefier rear end, you can get a Ford 9" rear with 4 channel ABS and keep your abs operation..
There's no 3-channel ABS setup for the Ford 9" rear, supposidly because there is not enough room in the center section to mount the reluctor ring..
Old Mar 12, 2004 | 12:47 PM
Hyperspeed97z28's Avatar
werd.. you dont want it....
Old Mar 12, 2004 | 01:20 PM
Capn Pete's Avatar
Re: ‘00 z28 no ASR ?!!
It sounds like you thought the ASR was like the "stability control" that some high end vehicles have, such as BMW's, etc. But it's not. Like the others guys are saying, it's just as well that you don't have it, since it can be annoying sometimes. I don't have it, but my friend who does, says he always turns it off when he starts his car up........................you know, sometimes you just feel like doing a smoke show and you don't need the computer trying to stop you!!
Old Mar 12, 2004 | 04:18 PM
Mike94ZLT1's Avatar
I'd happily give you my ASR if it were feasible
Old Mar 12, 2004 | 05:09 PM
99blackSS's Avatar
[whisper]It saved my *** one time.[/whisper]
Old Mar 12, 2004 | 06:59 PM
95GRNZ's Avatar
Wink
Kind of funny to see so many people complaining about the ASR.
It has a switch to turn it off when ever you like. Am I missing something...?
Old Mar 12, 2004 | 08:52 PM
97bowtie's Avatar
My SS came equipped with ASR. In normal driving, I don't even notice it. However, it's annoying when you try to bang gears and the car falls on its face. I'm already in the habit of turning it off every time I get in the car. The only time I have seen that it interferes with cornering is when you try to give throttle while turning. It will fight you and helps keep the car's *** end from stepping out (because it's detecting wheel spin...but it's not an active handling system). If you're new to these cars, it may be of some use...otherwise, it's just a pita.
Old Mar 12, 2004 | 09:49 PM
Klypto's Avatar
all it does it, when it feels tire slip, it SLIGHTLY hits the breaks, and makes you, no matter how hard pushed the gass pedal up... i leave it on normally... just turn it off at track.... its all a mind game for me, its the, "dont kill your tires button because your bored type thing"
cory
Old Mar 12, 2004 | 11:59 PM
97bowtie's Avatar
cory
"It" doesn't apply the brakes. It pulls the throttle cable back - that's why you feel the pedal pushing back against your foot when ASR is activated.
Old Mar 13, 2004 | 02:14 AM
Klypto's Avatar
i thought that, but someone told me it did bakes too.. guess thats net talk for ya....
cory
