Tuning help, track times fell off..
Ok well as said above i went to the track over the weekend and my times fell off, y? i have no clue.. all stock my car ran a 15.08 @ 92.5mph.. i've done all the mods in my sig this past winter and went to the track, the car ran a best of a 14.04 @ 97mph, consistant 14.1-14.3 depending on my fuel pressure and on my 60ft. time (2.01 is the best, averages about 2.02).. So anyways this past week i put on an MSD 6AL ignition box & Drag Radials and my car ran a best of a 14.65 @ 92mph!!!! what gives, faster ET than stock but the same MPH? yes weather condidtions are off a bit but that doesn't explain the lost 5 mph!! i'm not a happy camper, my cousin said the car launches awesome but then it just seems to fall on it face after that.. my Fuel pressure is set at 44psi, i started out at 46psi according to the dyno test results in the TPiS insider hints book, and as i brought the FP down it got quicker and i busted off the fastest ET, so i left it there, now like i said this weekend i haven't touched it and the cars runnin' slow again?? any help or suggestions??
1988 Camaro IROC Z28 (medium orange metallic)
LB9 305, G92 (3:23 gears)
Borla cat-back exhaust, AFPR (44psi), Port matched and polished entire TPi intake, Hedman Headers & Y-pipe, MSD 6AL Ignition, MSD Blaster coil, MSD wires and cap, TPiS Airfoil, Lakewood control arms, Hotchkis strut tower brace, B&M stage two shift kit, B&M Megashifter, Hypertech Thermochip, Hypertech 160* stat, Sub-frame connectors, K&N airfilter, !screens, Modified airbox, MJS ram air, Bypassed TB, deleted AIR
"1BAD 305"
WNYFA
www.UBRF.org
Check out my pix !!
My IROC Pix
More IROC Pix
"1BAD 305"
WNYFA
www.UBRF.org
Check out my pix !!
My IROC Pix
More IROC Pix
This isn't an Advanced Question and should be posted in 3rd Gen Tech.
Mike
1994 Sunset Orange Metallic Camaro Z28 Convertible - The Gorgeous and Sadistic Bitch Who Mistreats You and Lets You Down, Yet You Still Keep Her
1989 Red Ford Mustang LX 5.0 Convertible - The Dependable Girl Who Treats You Right, Yet Your Mind Wanders Elsewhere
Mike
Moving to 3rd Gen Tech......
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Fred
Detailed Mod's List
teedoff59
Aug 8, 2002 01:36 AM
