LT1 PCM for 400 sbc and FAST eDist compatibility ??
Old Aug 12, 2002 | 07:16 PM
cort351w's Avatar
Question LT1 PCM for 400 sbc and FAST eDist compatibility ??
I'm about to build a 406 sbc that will make about 500-550hp N/A. To save some money, I would like to use a stock ECM (LT1 or 730) if I can.
I want to use an MSD crank trigger and cam sync, LS1 coils, and a box to fire the coils that is also compatible with the stock PCM.
If I've read stuff on here correctly, then the Bailey box should work, right?
Also, is the FAST eDist compatible with the LT1 PCM? Is Motec's box?
On the other hand, would I be better off just using an aftermarket ECM?
Any help is very much appreciated.
91 Formula WS6, 305 tpi, 5-speed, 20k miles, ported & siamesed plenum and upper runners, K&N, SLP 1 3/4" headers, custom exhaust with Spin Tech Race Quiet muffler, Pro 5.0 shifter, Wolfe Racecraft SFC's, BMR rear "race" suspension and 3-point STB, steering brace, KYB GR2 struts/shocks, !AIR
"66" Shelby Cobra replica, my dad and I built it, 351W World block and Windsor J/R heads, Motorsport X cam, Speed Demon 750 DP, TKO, Currie 9", posi w/4.30's, 4-link suspension
69 GTO, hardtop, stick shift--SOMEDAY
01 Z06--stock, my dad drives it; I take care of it and Zaino it
[This message has been edited by cort351w (edited August 13, 2002).]
Old Aug 13, 2002 | 10:09 AM
Hal Fisher's Avatar
Post
I am no expert but its probably super cheap to at least try stock pcm first. Those other boxes are thousands with wiring, sensors, and software, right?
Hal
DirtyDaveW
Dec 1, 2016 05:37 PM
willismoons
Feb 14, 2015 08:42 PM
HectorM52
Jan 30, 2015 11:34 PM
Lederman1976
Nov 30, 2014 05:21 AM
