WTB: chassis wiring harness from a parts car
Old Feb 24, 2004 | 02:10 PM
PatrickCarter's Avatar
looking for the chassis wiring harness from a OBD 1 car 94 preferably, and a M6. This is the harness that has the under hood fuse block, and connects to the headlights ect.. It plugs in behind the brake boost cylinder.
Patrick
Patrick@fastbluetoys.com
Old Feb 25, 2004 | 01:49 AM
Random's Avatar
i got one of them things
hey i got one, its from a 95 camaro the only problem with it is that a factory gm alarm was removed from the harness so there's several wires that need to be spliced back together under the dash side of the harness... email me
freeland24@
comcast.net
^sorry for that stoping spam searchers
josh
Old Feb 25, 2004 | 10:10 AM
wires that need to be spliced under the dash? Cant you unplug it from the drivers side of the firewall?
THanks
Patrick
Old Feb 25, 2004 | 01:39 PM
Random's Avatar
yes and no all in the same breath, what i could unplug i did,
however certain cables, like the ignition cable gets cut ran thought the alarm and then returned... depending on how urgent it is for you, i can actually get all the splicing done and check all the wires for continuity.
i have three camaro's one did a bit of a jump off of a cliff, but most of it survived i've been carfully removing parts. I need most of the parts but that harness i don't need. If you want i'll splice the cable's together considering i have 2 camaros that are in peices i can copy the other camaros harness
don't know thought...
its your call as far as i'm concerned cause i don't really care about the harness right now, i will be putting all the remaining parts in working condition up for sale shortly. If you waited until then, i can promise the wiring harness will be fully repaired.
josh
Old Feb 25, 2004 | 02:16 PM
a7293's Avatar
Patrick,
I have the harness that you need. It came out of a '95z, with 64k mi. Email me if you are still looking. The harness is in good working shape. Nothing cut, all the clips are there.
Dan
a72oldss@yahoo.com
cmdeshon
Dec 12, 2014 10:51 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
CobraEatr
Jul 23, 2002 06:32 PM
