Ve table
Old Feb 22, 2004 | 06:44 PM
Schurters LT1's Avatar
Ve table
NOT TRYING TO START SOMTHING HERE !!!! WHAT ARE PEOPLE PUTING IN THERE VE TABLE FOR W.O.T
Or what would be the VE of our cars at wot
thx
Old Feb 22, 2004 | 06:57 PM
TriPinTaZ's Avatar
need more information. you runing a closed loop tune ?
what mods ? where and what kind of problem are you having?
you wont find much support here for VE tables. I am about the only person that believes they actually effect the engine on a MAF car. ( aside of Joe Overton )
but if you give me some more info I will try and help you.
Old Feb 22, 2004 | 07:59 PM
Hal Fisher's Avatar
Hypertech also edits the VE tables rather heavily for the Power performance tune. Though I am not sure what all they do to make it work. I would maybe use them to start with. TC has a feature to Import Table from a different file to exchange with the current open table.
Hal
Old Feb 22, 2004 | 08:53 PM
Car is fine ,tune is good , want to know what my Ve of the eng is so i can put it into the VE table of tuner cat...
i don't know if it works or not ...but hey can't hurt right
Heads and cam car all the bolt on's....
what info do you need..
thx
Old Feb 23, 2004 | 05:36 AM
TriPinTaZ's Avatar
Hal
Hypertech does not edit the VE tables. Only spark advance tables.
Old Feb 23, 2004 | 05:39 AM
TriPinTaZ's Avatar
thx
with a heads and cam car it may not be neccessary to edit your VE tables. Only if you experiencing poor engine running on cold startup. VE tables are usually left alone unless your running an extreme combination or you have cold idle/driving issues.
other than that the PCM can compensate for any minor differences in VE.
Old Feb 24, 2004 | 11:27 PM
i have just looked at my Ve tables and they are at 90 in wot ...
would my eng not have a higher Ve then this and if so what ....
Old Feb 25, 2004 | 12:49 PM
TriPinTaZ's Avatar
no engine is 100% efficient. mine only peaks at 94 in WOT and im FAR from stock. I would leave them alone if you do not know what or how they work. And even then you would need dyno time to even correctly tune the VE tables.
If you are not experiencing any drivability problems I wouldnt touch them. You need to understand that MY combination is very extreme and no MAF tuning would EVER come close to my engines fueling needs. There simply is not enough percision in MAF tables as there are in VE tables.
Old Feb 25, 2004 | 01:16 PM
turbo_Z's Avatar
Sure there are.. that is why people run S/C and turbos!
Schurters LT1,
First off for WOT tuning it is not necessary to touch the VE tables. For WOT you must adjust the Power Enrichment(PE) tables as that is what the computer restorts to for fueling demands. Now a word of caution... my MUST USE A WIDEBAND O2! If you do not use a wideband then you have no idea what the AFR is as a reference to adjust it.
Old Feb 25, 2004 | 11:42 PM
All my wot stuff is done on the dyno...Ve tables out .
when adjusting wot you use the PE table and the coolant something of wot???? as well right...what you do to one you do to the other...
DirtyDaveW
Dec 1, 2016 05:37 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
MichiganSkip
Jun 8, 2015 10:30 AM
90 Z28SS
Nov 9, 2002 10:07 PM
dayusmc
Oct 19, 2002 07:06 AM
