Lou's Short Stick Plus Hurst Knob Problems
Old Feb 21, 2004 | 11:02 AM
blu94Z's Avatar
Lou's Short Stick Plus Hurst **** Problems
Anyone have this problem? After installing Lou's Short Stick in my car and reinstalling the stock Hurst ****, when I tighten the **** down, it does not line up straight, but at an angle to the right. If I only tighten so that it's straight, it turns easily enough that during hard shifting, it turns in my hand. It's pretty annoying. Any suggestions?
Old Feb 21, 2004 | 12:02 PM
CODY BEHNKE's Avatar
I had the same problem with mine on my Hurst stick too. Just bare down on that SOB and turn it hard.
Be careful that you aren't twisting the leather.
Old Feb 21, 2004 | 02:18 PM
SilvercamZ28's Avatar
No problem like that with mine.... but a simple solution to your problem is... take your **** and start the thread so the handle points at 6 o'clock... then proceed to tighten back down... that is how mine lined up... Good luck!
Old Feb 21, 2004 | 02:29 PM
Ron78Z&01SS's Avatar
Loc-Tite maybe?
Old Feb 21, 2004 | 03:11 PM
PJS TOY's Avatar
The easy way. Drop a washer into the shift **** before you put it on the stick. It will take up some of the space and stop it from going too far to the right. If not enough, add a washer. You may have to experiment with different thickness of washers to get it right. It is NEVER a good idea to force a threaded part into place. Also, the threads ALWAYS start in the same place on both parts. that means that no matter where you start it, they always engage at the same point. I used this method on several shifter and **** combo's over the years, always worked.
Hope you haven't stripped or cracked it yet.
PJ
Old Feb 21, 2004 | 05:53 PM
blu94Z's Avatar
Haven't tried anything yet, will try some of your solutions. Actually thought of the washer thing, just not sure that would work, but will probably try that first. Thanks for all the help.
Old Feb 21, 2004 | 05:57 PM
Mikie's Avatar
I have the same damn problem
A friend told me to wrap a small amount of teflon tape around it and the try it. Dont know if that will work , but the washer idea sounds good too.
Mike
Old Feb 21, 2004 | 08:21 PM
chpmnsws6's Avatar
put a few linches of electric tape around the threads. make sure to have the tape the same direction the handle is tightened
slocody
Feb 10, 2003 01:04 PM
GRN96WS6
Sep 8, 2002 10:45 PM
slothgrant
Aug 22, 2002 03:01 PM
kurob25
Aug 5, 2002 08:03 PM
Krab
Aug 5, 2002 12:08 AM
