air filter collapsing with ati
Old Feb 18, 2004 | 07:03 PM
blownbird01's Avatar
What do you do if your filter is sucking shut when you are in boost? Mine is doing that and I was just curious if there is a fix for it out there.
Old Feb 18, 2004 | 07:36 PM
rskrause's Avatar
Moderator
Re: air filter collapsing with ati
The filter itself or the intake tubing? If it's the filter, I'd try a new one I guess.
Rich Krause
Old Feb 18, 2004 | 08:51 PM
Its the filter itself. It is very weak. I figured on just buying a new one but wanted to see if this was common.
Old Feb 18, 2004 | 10:44 PM
boosted-lt1's Avatar
might be helpful to put a bigger filter on......if you can.
Old Feb 19, 2004 | 06:37 AM
IDOXLR8's Avatar
Are you running the twin high flows? If so I would highly recommend going with a bigger filter. I had the same issue with my setup.
Old Feb 19, 2004 | 06:25 PM
I'm still running the 2core, but I'm going to upgrade to the twin set up here soon. Do you have a size on that filter so I know what I'm after?
Old Feb 20, 2004 | 06:48 AM
IDOXLR8's Avatar
Just look at your setup and fit the biggest filter you can.
Old Feb 22, 2004 | 08:40 AM
1st and goal's Avatar
Do you mean a big bastard like this
Marc
www.geocities.com/marcs94z28/4inchinlettube.html
Old Feb 23, 2004 | 07:26 AM
IDOXLR8's Avatar
Marc
Yep
PCLZ28
Dec 24, 2015 05:19 PM
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
Latronaxe
Apr 29, 2015 08:25 AM
SpeedJunkee
Apr 23, 2015 09:51 AM
kksi
Mar 21, 2015 09:03 PM
