transmission tragedy update - A4 guys inside please!
Old Feb 18, 2004 | 06:50 PM
sc93's Avatar
http://web.camaross.com/forums/showt...hreadid=225464
in reference to that thread.
I got the fluid to what I believe is the correct level.
The car shifts firmly now, and seems to be almost as good as new. The 1-2 shift is hard but not as hard as it originally was, the 2-3 and 3-4 are normal.
What are your opinions on this? Keep driving it more to get more ATF circulating, and get any air out of the system?
Add a little more ATF?
I don't suspect any internal damage but I am not 100% sure
Old Feb 18, 2004 | 07:48 PM
ead94z28's Avatar
Re: transmission tragedy update - A4 guys inside please!
Yes I would keep driving it for a while and see what happens. From your previous thread, it did not seem like you drove it anywhere when you had the fluid loss, so i don't see how you could have done any damage. Be thankful it was not as serious as it could have been.
Old Feb 18, 2004 | 08:00 PM
12SCNDZ's Avatar
If the governor cover came off all at once, you might be OK. I've seen this happen quite a bit. If it came off gradually, and you lost fluid over a longer time span, you may have hurt something. Usually loss of fluid will show up in the forward clutches first. Do you have any engagement problems?
Most of the time these covers come off is in 4WD vehicles. The ONLY time the governor applies pressure to the cover is when your turning the output shaft at high RPM's...IN REVERSE! They do it more in 4WDs because people go alot of high RPMs, in reverse, when they're stuck.
Frank
All-Trans Transmissions
Old Feb 19, 2004 | 07:10 AM
sc93's Avatar
Frank
by engagement problems, do you mean the transmission engaging when I press on the gas? or do you mean shifting it into 1st from park?
Old Feb 19, 2004 | 04:51 PM
12SCNDZ's Avatar
Is there any delay when you move the shifter from PARK to REV., or PARK to DRIVE?
Frank
Old Feb 19, 2004 | 06:00 PM
ead94z28's Avatar
Frank
I've always had a short delay. Even after a rebuilt tranny. Off topic...I see your from elkton. I'm from Havre de Grace, about 15 min. from you. Any good shops local that know a thing or two about these cars?
Old Feb 19, 2004 | 06:17 PM
sc93's Avatar
Frank
I didn't notice, I'll check that out later and let you know!
Old Feb 20, 2004 | 06:30 AM
12SCNDZ's Avatar
Um...I work at All-Trans, in Newark, Delaware. I've been building there for 7 years. Before that, I was at Deltrans, in Newark for 7 years.
PM me, and let me know what you need.
Frank
Old Feb 20, 2004 | 07:01 AM
sc93's Avatar
Frank,
I checked it out, there is a very minor delay from Park to 1st, but that seems normal to how it has always acted
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
mspennyhughes
Nov 28, 2014 03:22 PM
Red97LT1
Aug 7, 2002 05:45 PM
