What paint do you use on a rear?
Old Feb 16, 2004 | 05:13 PM
96 WS6's Avatar
Simple one sentence answer, thanks!
Old Feb 16, 2004 | 06:09 PM
ABA383's Avatar
Anything from Eastwood, "chassis black" works great.
Old Feb 16, 2004 | 06:16 PM
96 WS6's Avatar
Where can I order? Any others???
Old Feb 17, 2004 | 05:40 AM
bowtiepwr's Avatar
>I painted my Strange 12 bolt with 1 can of Rustolium black and covered it with their clear coat .
don't forget to mask off the vent and around the axle ends and the differential cover too .
Old Feb 17, 2004 | 09:40 AM
I used a Rustoleum semi-gloss black, except for the center section, where I used a "Hammertone Silver" to make it look like aluminum, and match the rear cover.
Strange 12-bolt
Installed (this is a very old picture...)
Old Feb 17, 2004 | 10:48 AM
Z95m6's Avatar
That looks good fred if i ever have mine out for a cleaning i might paint the center of it silver too.
Old Feb 17, 2004 | 11:18 AM
96 WS6's Avatar
Do you have to primer it or just get the paint and spray it on? Is there a specific rustoleum kind or any rustoleum black? On the rustoleum website there are plenty of different kinds of paint you can get.
Old Feb 18, 2004 | 05:45 PM
sir_z28's Avatar
A friend of mine used POR15 and it looks great. I plan to use the same and since it can be brushed on, there is no overspray mess. I used Rustoleum on my truck about 10 years ago and it has not held up very well.
Old Feb 18, 2004 | 07:53 PM
EDS Z28's Avatar
Rustoleum has some new paint called "Rustoleum professional". It is a heavy duty enamel. I didn't use it on the rear, but on some front end parts. It flows from the can really nice, you can tell a difference.
Old Feb 18, 2004 | 11:21 PM
Its always hard to remember what I did..... at least 4 years later.... .
I just poked around in the shelf full of cans in my garage....
It wasn't semi-gloss.... it was Rust-Oleum PROFESSIONAL (can't be too new) High Performance Enamel, Gloss Black, #7579. It is supposed to be suitable for application over bare metal. My Strange was brand new, no rust at all, and I just use some TSP to wash it down and remove all the grease and oil. Put some masking tape on the parts I didn't want to paint, and sprayed away. I could have done a better job getting up into the inside of some of the brackets.... 4 years later they are showing some signs of rust. Not the paint's fault.... mine.
The center section was painted with Rust-Oleum Premium Hammered Metal Finish, Silver, #7213. Again, direct application to the cast iron center section.
As a point of reference, this is what it looks like after 4 years.... needs a little cleaning and some touch-up
Strange
Old Feb 19, 2004 | 01:09 AM
AL SS590 M6's Avatar
Moderator
Hammerite ........... brushes right on over rust and everything. Looks great and long lasting.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Patricklt1
Apr 24, 2015 06:29 AM
Collector Car
Jan 5, 2015 10:58 AM
