Whats with my oil pressure ???
Old Feb 15, 2004 | 12:19 AM
SpeedzAdisease's Avatar
Question Whats with my oil pressure ???
For the last month and a half my oil pressure has stayed half way between 40 and the next mark. Today for some reason it has stayed a liitle past the mark right before 80. What gives ?? It does not drop down unless I'm in sixth gear. Should I be wary ? I know jack about this car, but a lot more than I did even a week ago b/c of you guys. Help !!
Old Feb 15, 2004 | 08:35 AM
jm8881's Avatar
I'm no mechanic, so I don't know what could cause that, but it sounds like somethign needs to be fixed. It might be something as simple as a new oil pressure sending unit.
Old Feb 15, 2004 | 11:52 AM
JKDGabe's Avatar
Was it colder that day? Pressure is resistance to flow so if it's colder you'll get more pressure.
Old Feb 15, 2004 | 12:39 PM
Slappy3243's Avatar
Our LS1 manuals say that our oil pressure can fluctuate between 6 psi when idling to 80 psi and it is still considered normal.
Old Feb 15, 2004 | 06:22 PM
cdmelcher's Avatar
sending unit
that sounds like a sending unit and I would take it to GM, it is not that expensive and from what I found out thru this site and when mine went it is somewhat common..
Old Feb 15, 2004 | 06:24 PM
Klypto's Avatar
on cold engine, mines JUST under next mark, once its running for a bit, 10 min?? goes back to just above 40
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
