tts datamaster problem
Old Feb 1, 2004 | 09:34 PM
tellum's Avatar
i installed tts datamaster ee 3.4.17
well, i got a datacable and a usb to serial adapter for my laptop.....i configured everything per datamaster's manual and it still wont read my pcm.
here is the error i get when i go to test the com port
"The ALDL adapter is working, and unknown data was detected. This may be an unsupported PCM type."
any suggestions?
Old Feb 1, 2004 | 11:10 PM
Tails's Avatar
Make sure you have the correct vehicle type selected. From the top menu look at Setup then from the drop down menu look in Vehicle Type.
Tails
Old Feb 1, 2004 | 11:17 PM
tellum's Avatar
yep
f-car A/T
i did that, selected the 'serial usb device in use'
configured the adapter in the control panel
everything the manual says to do
Old Feb 2, 2004 | 12:07 AM
Ryan94ZA4's Avatar
If you are using a USB adapter, that may be your problem. I finally gave up on USB and just bought a laptop with a serial port.
Ryan
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Captain Kirk
Aug 8, 2002 02:53 PM
Pro Stock John
Aug 1, 2002 09:18 AM
Captain Kirk
Jul 26, 2002 06:39 PM
