engine missing!!!!!!!!!
Old Jan 26, 2004 | 07:09 PM
1sloLS1's Avatar
alright i am not going to write a 9 page article but i will say the basic facts and see what you guys think. Sat., went to the dyno to see what the car would do on the TNT kit, first run we went NA for a baseline, the car ran fine. the guy shut it off to check the straps and went to go for the N2O run and the car starting missing as soon as he started the engine. I took the car to auto zone to use their code scanner and i am getting p0300(random misfire), i then take it to a buddies house with auto tap and the bank 2 o2's are inactive so i replace them. no help still missing. next i hook it up to a mac mentor to see what is missing and it is coming up that cyl 6 and 8 are missing that is it and the o2 are still not moving on that bank. i am straight up confused now i checked the ground in which all 4 o2 and the 4 coils on the right bank share. but the way i see it is if the ground was messed up then all 4 coils and all 4 o2 would be messed up. right now my hands are in the air with the whole thing. any help would be appreicated. thanks kevin
Old Jan 27, 2004 | 07:10 AM
silver96z28's Avatar
If you didn't already, try LS1.com, alot more people there to anserw that.
Old Feb 15, 2004 | 09:32 PM
teke184's Avatar
i got a similar problem.
drove the car 100 miles yesterday without the slightest problem.
fired it up this morning and right off the bat it would barely start and would not even come close to idle.
tried restarting several times to no availe.
finally it smoothed out after MUCH reving.
got the same code for random misfire.
is this a sign the o2's are bad?
Old Feb 15, 2004 | 10:47 PM
1sloLS1's Avatar
mine ended up having a ignition coil wiring harness bad it had melted the wires for cylinders 6 and 8 together causing it to misfire. if you have an o2 prob it will throw seperate codes for the o2's
armedtrigger
Feb 24, 2015 08:30 PM
DetroitZ28
Feb 13, 2015 07:33 AM
cmdeshon
Dec 12, 2014 10:51 PM
dmaastr
9
Jul 1, 2002 02:22 PM
