Autocross and Road Racing Technique There is more to life than a straight line
problem with wilwoods...
Old Sep 11, 2002 | 12:04 AM
brannan_john's Avatar
Post problem with wilwoods...
I just put the wilwood 13" rotors and 6 piston on my 96 SS. I have bled the lines four times and still have a sponge pedal and lots of travel. The brakes work, but only when the pedal is about 2 " from the floor. ANy ideas? I have heard that I might need a larger capacity booster etc, but not sure. ANy info would be appreciated.
thanks
John Brannan
96 SS #838
Old Sep 11, 2002 | 07:27 AM
Z28BICOL's Avatar
Post
You need to bleed it some more very carefully.
93Z28 Red/Blk A4 /STB/lower springs/JBA headers/Borla cat-back/285x35x18Nitto/Boyd Coddington Smoothie2 18x10//Random Tech cat/underdrive pulley/K&N KIPK/TR55 plugs/MSD 6+ digital/AFPR//BMR LCA,Panhard rod,SFC,LCA bracket/SLP torque conv/B&M tranny cooler/1LE sway bars/optima batt in spare tire well/Meziere H2O pump/HAL shocks/GM 3.73/TA girdle/Dennys HD drive shaft/Baer Track Kit brakes.
Old Sep 12, 2002 | 10:50 AM
I CORNER's Avatar
Post
I am not familiar with the 6 piston Wildwoods, but they may require too much fluid volume for your stock master cylinder, to provide the pedal feel you prefer.
I swapped to the Baer 13.15"x1.25" GT+ system, which uses Corvette C5 calipers and had no drop in brake pedal level.
Old Sep 16, 2002 | 04:48 PM
Acct 23749's Avatar
may be a stupid replie, but i make sure you have them on the right side. when i did Ls1 brake a year ago i did just that. the bleeder needs to be on the top not the bottom. so i had to switch sides. just a thought, i dont know if yours can be installed wrong or not.
Old Sep 18, 2002 | 01:26 AM
got it fixed
apparently the problem was bleeding the brakes. Unlike any cars I had bled before, the camaro has a ABS modual up under the hood near the brake res. Bleed these first (1 front, 1 rear) and then woprk aroung the car. Turned out great, and wow what a difference.
john
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
